t case problems
Old Mar 2, 2009 | 12:48 PM
partsguy7901's Avatar
partsguy7901
t case problems
does it sound like my tcase has went out. when i shifted from high range to low range truck acts like t case is in neutral got it in reverse once but came right out? any soulutions or thoughts
Old Mar 2, 2009 | 12:58 PM
bad96's Avatar
bad96
make sure the truck is in park or neutral then try to get into 4lo, or check the linkage
Old Mar 2, 2009 | 12:59 PM
partsguy7901
5 speed truck tried neutral and all gears. from the outside the linkage looks ok
Old Mar 2, 2009 | 02:07 PM
alxsnmr's Avatar
alxsnmr
it is possible the range fork in the T-case has become worn to the point that it wont hold the selected range. It will act like you dont have reverse because of the way the teeth are cut in the gear it is barely in gear for forward but slips out in reverse. Cheap piece to replace, pain in the tookus to get to though.
After reading your other post, definitely check to see if your linkage is shifting well before yanking the t-case.
Old Mar 2, 2009 | 04:00 PM
Rulebreaker's Avatar
Rulebreaker
Some truck info would be nice. It's my experience if you live in the rust belt that the shift lever seizes up and needs to be torn apart and greased well to operate properly. You need to crawl under the truck and verify the lever is operating the tcase properly. Then go from there. RB
Old Mar 2, 2009 | 05:54 PM
partsguy7901
i live in southern nc no real rust problems. is it possible that it is frozen? i just got this truck a couple of months ago, and havn't had a chance to change all of the fluids.
Old Mar 3, 2009 | 08:09 AM
alxsnmr's Avatar
alxsnmr
You are going to have to crawl under the truck while someone operates the lever to verify what is going on with the gear selector. Anything is possible with an older truck with unknown usage, including a bent linkage.
