EBay Front End Kits
Old Mar 2, 2009 | 07:28 PM
birchy's Avatar
birchy
EBay Front End Kits
Anyone have any experience with these?
Ball Joint TIE ROD Control Arm Ford EXPEDITION F150 KIT - (eBay.ca item 260291207409 end time 22-Mar-09 10:13:44 EDT)
Old Mar 4, 2009 | 01:47 PM
birchy's Avatar
birchy
Nobody?
My gut feeling tells me that the quality of the parts is probably not up there with Moog or Spicer..
But if it got me by for another year or two that would be great. Give me some time to save up some more $$$.
Old Mar 4, 2009 | 02:00 PM
alloro's Avatar
alloro
Originally Posted by birchy
Nobody?
eBay Store - Arm-Can Auto Parts: Chassis part Qualities and Prices
The guy specifically spells out the grade these parts are. He also says these are not Moog or Spicer parts, although he does carry those brands at a higher cost.
From the sounds of it, the grade of the parts he's selling are equivalent to say Autozone's own Duralast brand.
Old Mar 4, 2009 | 02:12 PM
birchy's Avatar
birchy
Thanks alloro. Not sure how I missed that. I suppose I'll have to weight the cost vs. quality and make a decision.
Old Mar 4, 2009 | 02:43 PM
alloro's Avatar
alloro
You know, once you take into account the shipping costs, for about $30 more you can buy all of those parts at Autozone. It would be their Duralast brand which is probably the same grade as the eBay ones. However, with Autozone you get a lifetime warranty on the parts. So if they should ever break or wear out you'll get replacements for free. Not a bad deal for the extra $30. It's also much easier and less truck downtime to run down the corner for the replacements instead of waiting for them to ship in.
Old Mar 4, 2009 | 02:56 PM
birchy's Avatar
birchy
Problem is, i'm in Canada and we don't have Autozone.
We do have Auto Value, and a few other similar names. Not sure if they're affiliated at all. Canadian Tire is the big chain.. and I'm wiilling to bet that's who he's referring to with this blurb:
The particular brand we carry is called "Chassis 1" and is distributed here in Toronto by a very reputable warehouse that also sells the same brand to a few big "Franchise Part Stores" (I'm not supposed to mention any names so I won't).
I think I'll call around and see if I can get comparable prices at one of the local chains.
Another somewhat related question... I'm shopping around for new tires as well, and one website is asking me to choose if my 2000 Expy EB has "19mm or 21mm hex". Any idea? Is that referring to the size of the lugnuts?
Old Mar 4, 2009 | 03:49 PM
alloro's Avatar
alloro
Yes, it's referring to the size socket need to remove the lug nuts, not the size of the stud.
Old Mar 4, 2009 | 07:06 PM
ford12508's Avatar
ford12508
if you have a ratchet set, hold up some ratchet heads next to the key that came with the car if it had one and see which one its closer to. You could also put a 21mm head on a ratchet and try to get it on the lug. if it goes on, its 21, if it doesnt, its 19. If you plan on turning the lugs, start with 19, as it will fit a 19mm lug, but not onto a 21mm lug. If you do a 21 and its 19mm, you might semi strip the lug.
Old Mar 4, 2009 | 09:52 PM
alloro's Avatar
alloro
Originally Posted by ford12508
You could also put a 21mm head on a ratchet and try to get it on the lug. if it goes on, its 21, if it doesn't, its 19.
I think you got that backwards buddy. A 21mm socket will fit over both a 21mm nut and a 19mm nut.
BTW, if a 19mm socket isn't available a 3/4" one is the same size, give or take a 1/4 of a mm. And a 7/8" will fit on a 21mm nut but a 13/16" will not.
Old Mar 4, 2009 | 09:54 PM
ford12508's Avatar
ford12508
thanks for the correction alloro.
I see there is no edit button...
Old Mar 4, 2009 | 10:04 PM
alloro's Avatar
alloro
There is a time limit for the edit button to be available after you first post the message. I'm not positive but I think it's 30 minutes.
Old F1
Mar 21, 2011 01:48 PM
oreocreaming
28
Aug 27, 2010 11:01 AM
roljr
Jun 9, 2010 07:22 AM
parrisw
24
Nov 27, 2008 08:42 PM
