Starting Problem - banging my head
Old Mar 4, 2009 | 08:42 PM
89BlackBeauty's Avatar
89BlackBeauty
I went out today to try to start, and the same thing happened, although it seemed to want to run as long as the starter was cranking. Before I started, I check the HPOP reservoir and it was about 3/4 below the top, the batts were at 12.5 volts. I turned on the key, and checked by GPR and it clicked over and I had about 11.5 volts on both terminals, I heard it click off after about a minute or so. Tried to start it, but it ran and died as soon as I let go of the key. I posted some pics to my album (and other post) on what some parts are https://www.ford-trucks.com/forums/8...ml#post7221522. The pshhh sound seems to be coming from under / near the driver side battery and sounds more like a motor starting (when not in the cab).
Thanks,
Old Mar 4, 2009 | 10:22 PM
adamzelazowski's Avatar
adamzelazowski
Check fuel filter if you have fuel there when you cranking.First picture i think is IPR.
Old Mar 5, 2009 | 07:37 AM
89BlackBeauty
I have drained it a few times (a little) using the valve, and it has refilled each time. I can hear the fuel pump running.
Old Mar 9, 2009 | 12:53 PM
89BlackBeauty
Well the problem was a worn electrical problem at the IPR solenoid connection. I replaced that, and it started right up. No problems this weekend at all. I plan on cleaning the engine compartment well, and make sure I do not have any more worn connections.
Thanks,
Jim
Old Mar 9, 2009 | 01:02 PM
zx250's Avatar
zx250
Of the next Riffraff East
Good deal, a bad wire can be a pain it find.
Old Mar 9, 2009 | 01:57 PM
superduty4x4's Avatar
superduty4x4
Originally Posted by 89BlackBeauty
When I turn the key, and wait a few seconds there is a psshhhhh sound - like a fart, that comes from the engine compartment (so its not me),
I can't believe nobody else even commented on this!
strokin'_tatsch
50
Feb 11, 2011 07:35 PM
tlsracer1
Nov 13, 2008 08:23 AM
BAD ROD
13
Oct 13, 2003 02:21 AM
FST351
Jul 23, 2003 09:52 AM
diesel demond
May 14, 2003 02:34 AM
