I have read alot about people putting 05-07 grills on 99-04 trucks. Which I know that you have to trim the bottom of the grill to make it fit. but I have not seen anyone confirm if the new style bumper just bolts right up or have to change mounts or something. also if you put the newer bumper on do you not have to trim the bottom of the new style grill???
Down here I see the grill swapped only. Looking at LMC Trucks catolog for Superduty trucks, it doesn't look bolt on to me. I'm sure there's a way to make it work though.
there are a ton of posts on subject some w/exl pics
but with my seach funtion inop cant hook u up
i gues it maybe fixed on monday or just wait
one of the pros will be along to attach some links today
Delete your "History" and "Cookies" on your PC. See if that solves the problem with the search feature.
furian thanx i tried that already have a ticket logged w/IT guy/guys
i guess not everyone affected but ive seen other post past 2 days same prob
will go and try again thank you
Ha! Just trying to help... I hope that you find a fix soon. Stuff like that drives me CRAZY!
moto hope i didny stall your post
figured someone would post a link about swaps been allkinds of info on subject
yep still no search man if this thing had a carb i could fix it
bumper is direct bolt on. with the new style bumper there is no grill trimming needed, i did the swap last year.
Thanks for all the reply's.. I just read from that thread joe posted and one guy said the new bumper needs 4 brackets and 2 brackets for the fog lights??? not sure if i read that right or not but just want to make sure.
yeah the fog light brackets are different, the bumper I bought came with the outside brackets on it, so I left the old brackets on the old bumper, if I recall correctly, the brackets do look different. But everything bolts into the same place on the frame.
So if the new style bumper doesn't come with the brackets will the brackets from my older bumper work???
