Clutch question
Old Mar 2, 2009 | 05:57 PM
creeker01's Avatar
creeker01
Clutch question
Hi,
Quick question -
1986 f150
4.9
3spd with o/d
Is this normal - Truck parked on slight hill left in fisrt gear without e-brake engaged will start to slip and lurch down the hill a few inches at a time.
Will do the same thing if its left in reverse.
do I need a new clutch or is this worse?
Old Mar 2, 2009 | 06:09 PM
uncle.stosh's Avatar
uncle.stosh
It just means that your e-brake is not engaging and your truck is slowly rolling forward in gear which is normal.
You might try putting it in reverse until you get the e-brake adjusted or fixed. It might help with the rolling because of the ultra low gear.
Old Mar 2, 2009 | 06:23 PM
creeker01's Avatar
creeker01
Hey - thanks for responding!
I meant to say - If I DONT have the ebrake engaged the truck will slip and roll down hill - and thats if its in 1st gear or reversed. Is my clutch toast?
Old Mar 2, 2009 | 07:14 PM
srercrcr's Avatar
srercrcr
That happens cause the engine is slowly rotating....the worse compression you have the worse this happens. Use the e-brake.
Old Mar 2, 2009 | 07:26 PM
creeker01's Avatar
creeker01
Now that makes perfect sense! Blow in my tail pipe and the engine will turn=)
Old Mar 2, 2009 | 07:31 PM
uncle.stosh
I'm NOT EVEN going to touch that one........
Old Mar 2, 2009 | 07:49 PM
bashby's Avatar
bashby
If you blow wouldnt it turn backwards?............nevermind
Old Mar 3, 2009 | 06:06 AM
srercrcr's Avatar
srercrcr
Back in the day, you could be sitting in the car on a slope and the car would slip back slightly.
Old Mar 3, 2009 | 08:24 AM
Freaksh0w's Avatar
Freaksh0w
Like said, it's probably the compression of your engine. I've heard of people talking about their trucks actually rolling in first gear low (NP435/T-18). Now that's a loose engine, lol.
Old Mar 3, 2009 | 09:00 AM
uncle.stosh
Hi,
Quick question -
1986 f150
4.9
3spd with o/d
Dude, you gave me NEGATIVE rep points for trying to answer your question?????
What's up with that?????
Thanks........
Old Mar 4, 2009 | 08:01 PM
creeker01's Avatar
creeker01
Total nube mistake! anyway I can change it around! meant to give positive! Sorry
Thanks........
