Lower Orange Boots
Old Mar 3, 2009 | 08:30 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Thank you for the link Orezona, I agree. The boots are very soft and the problem just began. Replacement is needed, that should give me 7 + more years.
Old Mar 3, 2009 | 11:10 PM
bdrummonds's Avatar
bdrummonds
Originally Posted by Whitey Ford
Brandon...Does the red and green tube in the middle of the picture below, pull out of the black rubber 90? I see how all the other disconnect. Probably change black and blue boots. They are very soft. I really appreciate the help.
Attachment 13623
Yes sir, just gently pull the red and green tubes out of the 90, they are single bulge barbed, and will come out easily.
Old Mar 3, 2009 | 11:31 PM
CSIPSD's Avatar
CSIPSD
Bobs boots are good quality, you can get the same thing from your local truck shop, but then you have to do all the leg work...
I have had bobs boots for about 4 years now, the one to the turbo has started to blow at about 45-47psi now... getting a little ragged, need to replace...LOL
Old Mar 4, 2009 | 05:30 AM
jdecker88's Avatar
jdecker88
Joe I believe your boots sees some out of the ordinary uses compared to the rest of us LOL.
Old Mar 5, 2009 | 06:23 PM
Whitey Ford
Does anyone know were I can get the boots without the fancy clamps, I already have those. Some seem rather proud of the boots they are selling.
Thank you...
Old Mar 5, 2009 | 06:59 PM
jeff7825's Avatar
jeff7825
Thank you...
Contact Riffraff Performance on here, he will hook you up.
Old Mar 6, 2009 | 12:04 PM
Whitey Ford
Any other ideas for the boots?
Old Mar 6, 2009 | 12:20 PM
brian42's Avatar
brian42
Veteran: Navy
Originally Posted by Orezona
I have these http://www.dieselsite.com/index.asp?...ROD&ProdID=133 with no CCV mod and no leaks or seeping oil.
Not saying anything is wrong with the CCV mod suggestions, just throwing out another option to the OP.
The boots are not oil resistance and the material will break down over time. There are several kits out there, but I got mine from Diesel Site as well (including the intercooler boots too, which is a separate kit). It is a PITA to work them on, but they are awesome. No more oil leaking and I don't have any more dusting issues either. They aren't cheap, but you get what you pay for. The trick is to spray some hair spray onto the end of the CAC tube before you work the boot on so you get some wiggle to get the boot onto it and the connection. Once the CAC tube is on, the hair spray dries and you are good to go. The kit comes with some great spring clamps too.
One of these days I'll get to the CCV mod...
TurfSpecOK
Mar 21, 2012 05:11 PM
Andy's Beast
Feb 29, 2012 10:46 AM
custom_nirvana
Jun 7, 2008 07:28 PM
F0rdF0rever
Aug 13, 2007 10:42 PM
ssp42
Feb 12, 2007 01:29 AM
