safety chains revisited
Old Mar 3, 2009 | 07:17 PM
TexasDiesel97's Avatar
TexasDiesel97
Bolting your chains on it ok, but do not weld your chains on. Welding them on changes the heat treatment of the steel and can make them weaker and more brittle.
Old Mar 3, 2009 | 09:06 PM
believer45's Avatar
believer45
DieselDirk, I was about to object to your saying not to use the quicklinks like THIS and wanted to give you ratings to support my position. The ratings I found support your position. 5/8 quicklink is rated at 6,800 lbs, 5/8 grade 80 transport chain is rated at 18,100 lbs. I did not realize the quicklinks were that weak. Mine will be coming off before the truck hits the road again (waiting on significant repair to left front suspension and brakes).
Thanks for the education this evening.
Dave / Believer45
Old Mar 3, 2009 | 09:09 PM
believer45's Avatar
believer45
TexasDiesel97, the chains on converter gears on semi trucks are bolted which definitely supports the no welding. Welding would be cheaper and faster both in manufacturing the converter dollies and replacement of the chain. Another issue is welding will heat the frame in a very high stress location on the dolly and on the A frame on the trailer.
Dave / believer45
Old Mar 3, 2009 | 09:42 PM
Diesel_Dirk's Avatar
Diesel_Dirk
I learned my lesson about quicklinks a few years ago, in form of a fine.
Glad to be of help.
Old Mar 3, 2009 | 10:27 PM
2 stroke man's Avatar
2 stroke man
wow, i didn't realize DOTs were so dog-gone strict elsewhere. they arent terrible here usually.
Americal_Vet
Mar 13, 2017 05:33 PM
rawn77
Jan 20, 2017 07:37 PM
snowdog79
All Things Towing
Jul 18, 2016 01:14 PM
horsebadorties
All Things Towing
May 6, 2016 09:39 AM
corksil
28
Sep 14, 2015 09:51 PM
