transmission problems! please please anybody.
Old Mar 1, 2009 | 09:12 PM
andrew1's Avatar
andrew1
I have a 93 ford f150, the truck has been sitting for 3 years it needed a motor so I put one in it, the transmission was shifting fine when the guy sat the vehicle up. i changed fluid and filter it shifted fine for about 3-4 days then it stopped shifting in 3rd gear I can put it in d2 or d1 and put it back in D. It will shift with no problems. So is my trans on its way out? In need of some help please.
Old Mar 1, 2009 | 09:16 PM
str8dogg's Avatar
str8dogg
Try checking for codes. Though the light isn't on, doesn't mean there aren't any. Just in case you are wondering!!1
Old Mar 1, 2009 | 09:18 PM
94E1504.9L's Avatar
94E1504.9L
if you have over 100 thousand miles its most likely that you will need to get her rebuilt soon....was it shifting hard at all???
thats a sign of the tranny going ...
Old Mar 2, 2009 | 02:01 AM
nighthawk285's Avatar
nighthawk285
Is it an AOD tranny? Check and adjust the throttle pressure cable
Old Mar 2, 2009 | 06:02 AM
andrew1's Avatar
andrew1
It's a E40D transmission, do you think it could be the torque converter locking up, i saw somewhere about that and also the throttle position sensor. The check engine light is on, im going to try and pull codes from it today.
Old Mar 2, 2009 | 06:33 AM
Lazy K's Avatar
Lazy K
Is everything else working OK? Does the engine miss or stumble? Does your speedometer work OK? When you changed the fluid did you drain the torque and did you use a Ford replacement filter?
Pulling the codes is the right thing to do, You can get a lot of useful info that way.
Old Mar 2, 2009 | 07:05 AM
andrew1's Avatar
andrew1
Truck runs fine no stumble or miss, but i notice on the way to work it shift fine.
Old Mar 2, 2009 | 07:23 PM
andrew1's Avatar
andrew1
Well I scan for codes got code 122, 152 so 122 was for the TPS. Since i had replaced the motor in the truck i just swaped the TPS off the old motor. And it shifts fine now, drove for about 3hrs no problem. Thanks for all the help.
Old Mar 2, 2009 | 07:29 PM
Newcomer's Avatar
Newcomer
I know when I lost the AOD in my truck I lost overdrive on the first day, then I lost drive on the second day, then on the third day I slammed it into park doing about 20 mph and that fixed it. I always hated an auto anyway. Sorry, still bitter, I like to shift by myself.
Old Mar 2, 2009 | 08:53 PM
1966Tbird's Avatar
1966Tbird
hahahahahahahahahah LMAO thanks for the laugh man
i got pissed at the fuel injection and grabbed wire cutters and never looked back
Old Mar 2, 2009 | 10:08 PM
460/5's Avatar
460/5
Zombie Survivalist
i soooo have to agree...
MetalCowboyWilliams
Jul 18, 2014 07:52 AM
zombiesawyer
Jan 25, 2010 09:07 AM
mark_fussell
Mar 1, 2009 09:52 PM
01HARLEY
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 5, 2005 07:38 AM
