1978 - 1996 Big Bronco
intermitant ratching sound
Old Mar 1, 2009 | 07:49 PM
paulsextra's Avatar
paulsextra
1990 bronco, manaul trans, about 1 out of 10 times when i drive it i hear a ratching sound. seems to be louder sometimes than others. sometimes i only hear it when driving by a building or something to reflect sound. one time it happened i pushed in the clutch no change, shifted to nuetral, no change. came to complete stop and started again and noise was gone. the truck has manual transfer case and automatic hubs. thanks for any help.
Old Mar 2, 2009 | 07:27 AM
alxsnmr's Avatar
alxsnmr
check to make sure the auto hubs are disengaged. Sometimes they stick and make some very strange noises.
Old Mar 2, 2009 | 10:28 AM
Kemicalburns's Avatar
Kemicalburns
i would also pull the rear diff cover and inspect the spider gears. if there is an LS out back its possible that its worn out and your spider gears are causing this. probably could use new fluid anyway if you have never drained the rear diff.
Old Mar 2, 2009 | 06:17 PM
paulsextra's Avatar
paulsextra
i do think its probably the hubs. how do check to be sure they are disengaged. should i jack it and spin the tires.
Old Mar 2, 2009 | 06:31 PM
big bad 79 bronco's Avatar
big bad 79 bronco
yea do that also check the front axel shaft u-joints make sure there not worn
Old Mar 2, 2009 | 07:58 PM
helirich's Avatar
helirich
If his hubs are not engaged, and hes in two wheel drive, the u-joints are not the culprit. My vote is the hubs.
Old Mar 3, 2009 | 06:23 PM
paulsextra's Avatar
paulsextra
if the hubs are sticking, what is the fix.
Old Mar 3, 2009 | 06:50 PM
H2OnO2's Avatar
H2OnO2
New Bronco guy here with a question for the thread. My 90 Bronco has manual Warn hubs. I didn't know Broncos could have auto hubs. Aftermarket? Factory option?
Any advantage for either?
Old Mar 4, 2009 | 10:42 AM
Kemicalburns
auto hubs are junk and should be swapped.
Paulsextra, get a haynes manual and perform the maintanence in the book.
Old Mar 5, 2009 | 01:50 AM
paulsextra's Avatar
paulsextra
the auto hubs are factory. i will look in to manual hubs. thanks for the help.
Old Mar 5, 2009 | 03:01 AM
Packrat Super duty's Avatar
Packrat Super duty
How long has this been going on?
My old 78 Bronco had a simalar sound, turned out to be the CV joint on the rear drive shaft. When it first started to go, it was a clicking noise, came and went, then one day I decided to check underneath. .. (The clicking had increased in frequency). Turned out the CV was ready to fall apart. It was completely shot, but the u joints on either side of it were in good shape..... That was all that was keeping it together.
Just my 2 cents worth.
RickTFL
Apr 29, 2014 12:14 AM
pjnadon
Dec 12, 2010 08:15 AM
Octane
1997 - 2003 F150
35
Oct 2, 2008 06:57 AM
Mr.Ford 351W
Garage & Workshop
Jan 16, 2007 12:03 AM
1BadF150
1997 - 2003 F150
28
Jan 13, 2005 04:23 PM
