Toruqe spindle nut down to 60 ft lbs and then back off 7 clicks if you kept your used bearing IIRC.I did this to mine this summer. Is this what you found?
60 ft-lbs is the correct torque per Ford specs.
"Tighten the hub nut, rotating the rear hub occasionally while tightening. Tighten to 60 ft-lbs.
Adjust hub nuts as follows:
For new bearings, ratchet back five teeth or notches (1/8 turn) on the hub nut. Five notches must be felt during this operation in order to have performed it correctly.
For used bearings, ratchet back seven teeth or notches (1/6 turn) on the hub nut. Seven notches must be felt during this operation to have performed it correctly."
Quote taken directly from my Ford dvd manual.
Yes thats what I found was 60 pnds then back 7 clicks but there was also a topic i found where it was 70 ftpnds then turn back 1/4 turn and retourque to 20 ft pnds but i cant seem to find it now.
For used bearings, ratchet back seven teeth or notches (1/6 turn) on the hub nut. Seven notches must be felt during this operation to have performed it correctly." Quote taken directly from my Ford dvd manual.
I have a Ford published dvd that contains the same info that the Ford techs use when servicing vehicles. I usually copy & paste this info when posting.
Here is an illustration that accompanies the text to re-enforce the accuracy of the torque spec.
