1966 - 1977 Early Broncos
Will these heads work?
Old Mar 1, 2009 | 06:39 PM
hdfx81's Avatar
hdfx81
Will 69 302 heads work on a 79 block? The water jacket holes are different on the top of the head and block. Head casting #is DO0E, block casting is 90E-6015-E3A if that helps. I can't post a pic to show the difference.
Old Mar 2, 2009 | 09:22 PM
Boba Fett's Avatar
Boba Fett
The water jacket holes are different on the heads where the heads meet the intake on the earlier and later 302 heads.
I would ask over on the small block forum about what intake and head gaskets to use. I think the head gaskets are all the same for 302 regardless of year, but the intake gaskets are different.
Old Mar 3, 2009 | 05:04 AM
hdfx81's Avatar
hdfx81
I was planning on using the stock intake off my 72 motor so I should be ok there. thanks for the reply I will check out the small block forum
krewlstang
Feb 28, 2015 11:01 AM
bigcrunch
Mar 29, 2014 08:31 PM
RicksF100
Feb 20, 2005 05:57 PM
BigBlockFord3
Apr 27, 2004 11:29 PM
