D3ve
Old Apr 27, 2004 | 10:09 PM
BigBlockFord3's Avatar
BigBlockFord3
D3ve
this is what i found on my cylinder heads,the block has D2ve what the h-ll,y would the block and heads have different casting numbers,an does anyone know the valves sizes for this casting,an cc of the head,i have a set of TRW Pistons Part#L2404-40,was trying to figure what kind of compression i would be moving up to thanks
Old Apr 27, 2004 | 11:29 PM
81f2504x4's Avatar
81f2504x4
it is possible
the heads are pretty common heads at about 95-97cc's. your comp ratio is going to be about 8.5-8.8:1. I am just estimating this because i am using the same pistons on my 460 with the early D0VE heads and will get 9.5:1. You will want to make sure that you have the D3 heads and Not D2's because the D2's are the one that gave the 460 heads the bad rep for detonation. Also the valve sizes should be the same as any stock 460 without looking in my book i think they are 2.07 and 1.66 not sure but close.
adam83
41
Aug 20, 2015 12:01 PM
eperky
Dec 24, 2007 10:42 AM
redneckchuck
New Member Introductions
Feb 11, 2007 07:14 AM
desperado_18_2000
Sep 28, 2004 08:57 AM
chopper
May 14, 2001 02:06 AM
