What does the second oxygen sensor do?
Old Mar 1, 2009 | 04:41 PM
460's Avatar
460
1997 Ranger 4 cylinder.
What does the second oxygen sensor, the one after the cat, do?
Does it affect performance at all, or just an emissions reporter?
Old Mar 2, 2009 | 09:32 AM
sfcwoodret's Avatar
sfcwoodret
The oxygen sensor is positioned in the exhaust pipe and can detect rich and lean mixtures. The mechanism in most sensors involves a chemical reaction that generates a voltage (see the patents below for details). The engine's computer looks at the voltage to determine if the mixture is rich or lean, and adjusts the amount of fuel entering the engine accordingly.
The reason why the engine needs the oxygen sensor is because the amount of oxygen that the engine can pull in depends on all sorts of things, such as the altitude, the temperature of the air, the temperature of the engine, the barometric pressure, the load on the engine, etc.
Old Mar 2, 2009 | 10:11 AM
johncfox's Avatar
johncfox
The sensor after the converter meaaures the amount of gasses unburnt by the converter. It is there to monitor the efficiency of the converter. If the converter is damaged or removed or the sensor goes bad it will trigger the check engine light. The engine will still run fine though.
wikdwest
Jul 20, 2014 01:54 PM
wikdwest
Jul 19, 2014 12:12 AM
oxphatxo
The Next Generation
Jun 21, 2012 11:40 PM
SKI-V10
Modular V10 (6.8l)
Mar 17, 2011 09:26 PM
capstan
Apr 14, 2005 08:02 AM
