engine swap
Old Mar 1, 2009 | 09:14 PM
muscletruck's Avatar
muscletruck
engine swap
i have a 95 4wd extended cab ranger w/ a 4.0 and auto trans. it was wrecked when i got it but im going to fix the damage and make it my daily driver. i want more power and alot of people swap in a 302 or 351w. i like to be different and want to swap in a 4.6 or 5.4 modular motor. any tips or ideas to make this work?
Old Mar 1, 2009 | 11:14 PM
Old93junk's Avatar
Old93junk
Modular V8 is too wide, it can be done, but it is MUCH easier to go with a smallblock 302/351. And adapters and parts for small block swap are readily available.
Old Mar 2, 2009 | 06:15 AM
monsterbaby's Avatar
monsterbaby
as noted the mod engines are very wide, it has been done in the past but you have to remember that a 4.6 is actually wider then a 460.
A 302 gives these little trucks quite a bit actually.
But if you really want that mod motor there isn't going to be any kits that I know of, it's a build your own deal. But a possible suggestion that might make it easier and maybe almost a bolt in would be to find a V8 explorer with a 4.6 (my 02 has that engine) would be where I would start personally.
Old Mar 2, 2009 | 01:59 PM
muscletruck
thanks for the input. if i do that swap my plan was to find sumthing wrecked to steal all the parts out of.
Bossman77
Jan 2, 2011 04:38 PM
mtnboy21
Dec 25, 2010 06:14 PM
hav24wheel
Sep 22, 2010 01:24 PM
bronco lover
1978 - 1996 Big Bronco
15
May 19, 2010 08:28 AM
76250highboy
Engine Swaps
Mar 9, 2005 11:47 AM
