Oxygen Sensor P0056 2000 expedition
Old Jul 17, 2014 | 02:56 PM
wikdwest's Avatar
wikdwest
My expedition had a stutter while driving, when i would step on the gas it was like there was no fuel flow. Had a SES light and went to Advanced Auto to get the codes read. P0056 came up and after some research I found this:
Heated Oxygen Sensor (H2OS) Bank 2 Sensor 2 circuit open shorted to ground – Heated Oxygen Sensor (H2OS) Bank 2 Sensor 2 circuit poor electrical connection – Faulty Heated Oxygen Sensor (H2OS) Bank 2 Sensor 2 circuit – Heated Oxygen Sensor (H2OS) Bank 2 Sensor 2 circuit fuse – Faulty Engine Control Module (ECM) The Error code is generally activated on detection of the following conditions: The P0056 is set when the ECM detects an open or shorted to ground condition on the heated oxygen sensor heater circuit.
Solutions The code means that there is a problem with the heater element circuit of the heated oxygen sensor. Water getting inside the heated oxygen sensor connector can caused the heated oxygen sensor fuse to blow, which is a very common problem for this type codes. Before replacing the sensor, check for the condition of the heated oxygen sensor fuse and connectors. HO2S Heater Control Circuit Bank 2 Sensor 2 is the generic definition for the P0056; however your vehicle’s manufacturer may have a different definition and information for the P0056 code.
Will a bad oxygen sensor cause the truck to stutter like there is no gas? Does anyone know which oxygen sensor this is, Bank 2 Sensor 2?
Thanks for any help.
Old Jul 20, 2014 | 01:54 PM
alloro's Avatar
alloro
Sensor 1 can cause engine issues but not sensor 2. Sensor 2 is there mainly to monitor the efficiency of the catalytic converter. Bank 2, sensor 2 is the one after the catalytic converter on the driver's side.
wikdwest
Jul 19, 2014 12:12 AM
Chopper-Boyz
1983 - 2012 Ranger & B-Series
Apr 25, 2011 12:13 PM
svtcobra041
1997 - 2003 F150
Jul 15, 2010 09:19 AM
foxykool
Exhaust Systems
Jan 4, 2010 11:24 AM
geoaigel
Jan 10, 2005 10:50 AM
