Hissing While turning ?'s
Old Feb 28, 2009 | 08:20 PM
deetown's Avatar
deetown
I noticed a few days ago that when I turn I am getting a hissing noise at the drivers side firewall when I turn the steering wheel but it goes away when I step in the brake. Has anyone ever had this issue and if so what was it that was causing it? I have checked the powersteering and brake fluid and they are both fine. Any suggestions would be great. Thanks
Old Feb 28, 2009 | 09:34 PM
74baja's Avatar
74baja
I seem to have this issue too. Although, mine seems to happen mostly in reverse, especially when I throttle up a little bit.
Old Feb 28, 2009 | 10:19 PM
USAF CCM's Avatar
USAF CCM
Could it be just your power steering pump making it's normal noise when you've turned the steering wheel all the way? If not, check vacuum lines near Brake boost/master cylinder.
Old Mar 1, 2009 | 05:13 AM
white Buffalo's Avatar
white Buffalo
Does it go away after the truck has some time to warm up?
Old Mar 1, 2009 | 05:38 AM
just another truck's Avatar
just another truck
Last, did you by chance add power steering fluid at anytime?
Old Mar 1, 2009 | 06:14 AM
zx250's Avatar
zx250
Of the next Riffraff East
That's where your hydro booster is mounted and like the others are pointing to, it uses fluid from the power steering pump. ATF and not power steering fluid. Might be a good time for a fluid flush.
Old Mar 1, 2009 | 10:23 AM
deetown's Avatar
deetown
The only time it goes away is when I press on the brake while turning. It does not go away when the truck is warmed up. But if I am just cruising down the road with only a little turning it is ok. It is not coming from the powersteering pump but from the hydro booster on the fire wall.
kstiner
Aug 20, 2011 10:52 AM
kstiner
Aug 19, 2011 04:11 PM
cklecker
37
Jan 13, 2010 03:19 PM
Sycostang67
May 2, 2005 03:53 AM
datchew
22
Apr 19, 2005 09:14 AM
