Aod
Old Feb 28, 2009 | 06:46 PM
bfbiker's Avatar
bfbiker
Talking Aod
Ok here goes it
I went a bought a 1990 E150 for the motor and trans for my 1985 F150 was told it was a plug and play swap( ha ha) well its not both 5.0 both door jam trans code is T
the 90 trans has at the speedo the cable and a place to plug wires in too
the 85 onl has the speedo gear no wires
when cking on line it say that the 90 shold be a AOD but Im thinking its a AODE both van and truck had on the shifter PRN( D) 21
so is there any way to make the 90 trans work like gut it and swap it in to the 85 case or some way to make it work just the way it is I really need to get this back on the road asap
If I had know someone give me bad info on it i would have pulled the 90 wireing and stuff( I did pull the computer though) rest of the van has been crushed all ready
sorry for this being long and thanks for any help
Old Feb 28, 2009 | 08:14 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The first year for the AODE was 1992.
Old Mar 1, 2009 | 11:37 AM
bfbiker's Avatar
bfbiker
Talking 1990 aod
ok its AOD not AODE what are the wires for on the 90 and I was told here that all I have to do is use the gear from the 85 on the 90 and it will work
so is this ture You sound like you know what your are doing on this
so if this works what were the wires on the 90 for
Thanks Phil
Old Mar 1, 2009 | 11:54 AM
Mark Kovalsky
There are wires for the neutral safety switch. There are also wires for the vehicle speed sensor, in the '90 it was used for cruise control, maybe for the speedometer, I can't remember that far back.
Old Mar 1, 2009 | 11:57 AM
bfbiker's Avatar
bfbiker
aod
the van didnt have cruise on it
so what your saying is to go for it
thanks again mark
phil
Old Mar 2, 2009 | 09:14 PM
aaron ford's Avatar
aaron ford
If you pull the electronic assembly off the speedometer gear, you will find the exact same part that is on your 85. The VSS just pulls off. We pulled the gear out of a 91 van and after pulling the VSS off the gear, it fit in the cable from a 55 T-bird which we also found had the same end as a late 60's ford truck. I am pretty sure it will fit in your 85.
Aaron
Old Mar 3, 2009 | 09:11 AM
bfbiker's Avatar
bfbiker
Talking Aod
Aaron
Oks Im going to frrl really dumb with this one I bet
got the tv link off the trans but cant get the shifter link off the trany dont want to pry to hard on it so how do I get it off
