Altenator ?
Old Feb 28, 2009 | 04:34 PM
whiteaddiction's Avatar
whiteaddiction
Altenator ?
The big black/red wire on the back of the altenator has burnt off twice. I have put two different connectors on it in one year. The last time I made a copper rod with one end threaded and a set screw for the wire to be held in by. This has worked so far, But now my valt gauge is low again witch is how I usually know if the wire has burnt off. Its still attached but the copper and wire get very hot. I checked the glow plug relay and it works good, the glow plugs are not on. A volt meter shows it charging at 13.36v. Is there a voltage regulator on these trucks?
Old Feb 28, 2009 | 04:43 PM
jeep1947's Avatar
jeep1947
What year truck? IIRC it has external voltage regulator someone will correct me if I am wrong.
Old Feb 28, 2009 | 10:50 PM
whiteaddiction
its a 95 f350
luthrobediesel
18
Oct 23, 2010 06:16 AM
mob56437
Apr 8, 2010 03:05 PM
poffutt
1978 - 1996 Big Bronco
Aug 23, 2005 11:07 AM
poffutt
Electrical Systems/Wiring
Aug 19, 2005 04:08 PM
jevfro
Oct 15, 2003 05:53 PM
