1978 - 1996 Big Bronco
Newbie Bronco question
Old Feb 28, 2009 | 02:51 PM
7278ford's Avatar
7278ford
Hello all, I just picked up my new project. It's a 72' F100 on a 78' Bronco frame. The frame and drive train are stock bronco parts. My question is, what would cause the power steering fluid to bubble out of the cap once the rig is shut off? I suspect possibly a bad line building back pressure up but not for sure. Any help would be greatly appreciated.
Old Feb 28, 2009 | 03:27 PM
big bad 79 bronco's Avatar
big bad 79 bronco
either over full or if the fluid is bubbley looking it is low and the pump is aerating the fluid does the power steering work good with truck running hope this helps let us know
Old Feb 28, 2009 | 06:05 PM
7278ford's Avatar
7278ford
At first it did work good, but by the time i got home I was turning to the left with out power steering. Turning to the left is very hard but I do have decent power assist to the right. The guy I bought it from had just put fluid in it because he said it was low.
Old Feb 28, 2009 | 08:03 PM
kingford72's Avatar
kingford72
there is trans fluid in there isn't it, it should be type f. Does the truck have a cooler or return line that is higher that the power steering pump?
Old Feb 28, 2009 | 08:10 PM
7278ford's Avatar
7278ford
I don't think there is any trans fluid in there. Everything that is coming out is completely clear.
Old Feb 28, 2009 | 08:24 PM
kingford72's Avatar
kingford72
I ruined a power streering box and pump when I changed fluid one time because I ran power streering fluid in it, ford calls out trans fluid type F in the service manual. The steering acted real weird like you couldn't turn it then the seal in box went out I got a new box and that did the same thing they told me I didn't get the air out but I played with that thing for a while and took it back and they honored the warranty on it and I got a new box this time I did a little research before putting it in when I used the trans fluid everything went great except I put a old trans cooler and filter in the line since they were above the cap every time you turned the motor off the fluid would rise and overflow out the cap. this was a long time ago one of those things you call a learning experience.
Old Mar 1, 2009 | 08:05 AM
7278ford's Avatar
7278ford
I must be missing something. Did you put the cooler in yourself or was that stock?
Old Mar 1, 2009 | 01:37 PM
big bad 79 bronco
most dont have the cooler unless u have the heavy duty cooling option with the big radiator try trans fluid in it make sure all air is out turn wheel both ways against locks and should bleed all air out
Old Mar 1, 2009 | 03:22 PM
kingford72's Avatar
kingford72
yeah I put the cooler in
Old Mar 1, 2009 | 03:31 PM
kenpobuck's Avatar
kenpobuck
Kinda sounds like the valveing in the box may be about shot. This has happened to me before and some times it would work some times not. Finally bought a new box and that fixed it for good. You are right about the type f fluid though. I still use it in my power steering box on my 88 works better than the clear high dollar stuff lol. If you do change the box make sure to drain the pump and lines before adding the type f fluid they don't mix so well.
Old Mar 1, 2009 | 07:09 PM
7278ford's Avatar
7278ford
So I need to switch to tranny fluid as a start sounds like. Do you just pull the line off to drain the system, and how do you get the fluid out of the box? Is there a way to find out for sure if the valving is bad?
Old Mar 2, 2009 | 08:27 PM
greystreak92's Avatar
greystreak92
You can "hand wind" the fluid out of the box but don't let the engine drive it, you run the risk of cavitating the pump if the previous issues you described haven't already done so.
The fluid issue is simple, regular PS fluid lacks the viscosity that the Ford PS pump was designed to operate with. The Ford unit has both an aluminum casing and an aluminum impeller and with the wrong viscosity fluid, you either overheat the unit or you never get enough pressure. Either will eventually cause damage to the pump. The fact that both the casing and impeller are made of a relatively soft aluminum alloy makes them susceptible significant damage in a very short period of time if the fluid level is low, the unit overheats, or the wrong fluid is employed. (Everyone knows how to tell when an old Ford pulls up next to you... the PS whines and growls at you)!
Old Mar 2, 2009 | 08:50 PM
7278ford's Avatar
7278ford
That is exactly what mine is doing, whining and growling. Is there a way of telling if I have a damaged pump, or is the fact that the pump is whining and growling at me indication enough?
Old Mar 24, 2009 | 09:01 PM
7278ford's Avatar
7278ford
Update: I rebuilt the power steering pump with not so good results...after the rebuild i had NO power steering at all. I got a new spool valve and replaced it only to end up back to where I originally started with power assist to the right and nothing to the left.
I have also switched to trans fluid and I am getting a very bubbly fluid almost foamy looking after I drive the truck for a bit. I have also checked the pressure line for clogs and replaced the return line with all new. I am wondering if pump is bad and aerating the fluid rather than fully pressurizing it through the box..
Any more thoughts at this point???
Old Mar 25, 2009 | 10:14 AM
greystreak92
Sounds like it's just time to bit the bullet and go with a new pump. The aeration is a symptom of a cavitated pump or a LOT of air still trapped in the system.
No one wants to hear that I know but it beats chasing this problem around.
From my personal standpoint, I would take the opportunity to consider doing a Saginaw swap. The pump is of better construction and will handle the strain of swinging tires around under your 72/78 a lot better. The Saginaw unit was used in the Econoline vans so finding one for a Ford shouldn't bee too tough. Bracketry could be depending upon the engine you have.
