1978 - 1996 Big Bronco
Newbie Bronco question
Old Mar 25, 2009 | 09:32 PM
7278ford's Avatar
7278ford
Do you have the year for the econline's that these were used in? I have the 351m. I also have 33 x 12.50 tires that don't help the situation either. I took the pump apart today and I think the check valve in the pump is bad. I tried blowing compressed air into the valve only to have it blow right back at me. I also noticed that when I turned the wheel while the truck was sitting the pump would shake and growl at me as though it was straining. So I do believe it's the pump but am interested in this saginaw swap you refered to.
