yet another instrument cluster question....
Old Feb 28, 2009 | 01:18 PM
fishforlife2007's Avatar
fishforlife2007
ok. i have a 95 F150 flare side with a 5sp MT. the engine is the bulletproof 300. i searched on here and found that i can swap instrument clusters so i can get one with a tach. in it which would be very nice. as far as that goes, as long as i can locate on the same year, is it just a plug and play? i saw that it said i would be using the everything in the new cluster except taking the spedo. out of the old and placing the new. so once i do that, even though some of the guages are in different places on the new cluster compared to the old, everything should work out rite? harness still the same.? if that is the case do i just do that simple swap, plug it in and whala! it works? or do i have to do some seperate wiring? anyone who has done this, or has pictures of their install, and has any pointers would be much appreciated. i read all of the article, it just seemed a little "vague". thanks.
Old Feb 28, 2009 | 03:07 PM
quicklook2's Avatar
quicklook2
go to articles/specs at top of this page and find the article on how to do what you just asked.
Old Mar 1, 2009 | 09:18 PM
fishforlife2007
as i stated above i have already searched and read the article, and again, it still seemed a little vague on everything.. my main question is whether or not i just plug the new cluster in with the tach if it will just work right off the bat or what.
Old Mar 1, 2009 | 09:28 PM
quicklook2's Avatar
quicklook2
get a 95 cluster and change your speedo and it will be fine.
don't know what else to add.
Old Mar 1, 2009 | 11:32 PM
12secondstang's Avatar
12secondstang
The speedo center section is the same in both tach and non tach clusters. You need a 94 or 95 cluster for the tach/cluster swap. Yes it is plug and play as far as the harness is concerned. Take out old and put in new. Done.
Old Mar 1, 2009 | 11:44 PM
Jermafenser's Avatar
Jermafenser
How do you hook up the tach?? Is the wire already in the dash hanging around?
Old Mar 2, 2009 | 10:14 AM
quicklook2's Avatar
quicklook2
it is part of the harness already there.
you do not have to do anything but hook it up.
it is plug and play.
this is a real simple addition to your truck.
don't make it harder then it is.
Old Mar 2, 2009 | 10:16 AM
fishforlife2007
thanks for all the help guys...ill let you know how it goes
Old Mar 2, 2009 | 10:31 PM
TexasGuy001's Avatar
TexasGuy001
You don't even have to change out the speedometer with your old one. You can just put the whole cluster in it.
I put a Lightning cluster in mine.
The only reason to change out the speedometer/odometer is to retain your mileage.
Old Mar 2, 2009 | 10:42 PM
Tom92F150's Avatar
Tom92F150
x2.
Just don't try to use a diesel tach. It won't work.
