Ouestion about displacement
Old Feb 27, 2009 | 08:45 AM
me Mickey C's Avatar
me Mickey C
I read an ad the other day about Volkswagen diesels, they generate more HP & almost as much torque as my 7.3 & they do it with a small 4 cylinder engine, my mother has a nissan sentra ( 4 cylinder ) small displacement that has as much HP as my diesel, the V8 in my gmc is 4.8L ( 292 cubic inchs ) & it is 270 Hp. So here is the question, what happened to the idea that displacement equals horsepower? in the old days you were doing good if you could get 1HP for every cubic inch of an engine. My 7.3L is about 446 cubic inches but only 184 HP, what happened to the HP?
Old Feb 27, 2009 | 09:32 AM
Hallworth's Avatar
Hallworth
A diesel motor isn't about horse power. If you want big horse power go buy a gas motor.
Diesel's are all about torque and longevity. As far as your concerned about smaller diesels out performing your 7.3l, well your Motor is really old technology, and there are a lot of new diesel's with smaller displacements that can out perform an IDI. 90% of people on here have IDI's because there a cheap dependable workhorse, the other 10% because the love the motor for one reason or another. If you don't fit in two either of those two catagories, there are some other diesel's out there for you like a cummins, or a duramax.
Old Feb 27, 2009 | 10:27 AM
dyoung14's Avatar
dyoung14
smaller motors also rev alot higher than our motors, idis are about the most dependible, and can make good power with the right mods.
Old Feb 27, 2009 | 11:12 AM
David85's Avatar
David85
Newer engines often rely on overhead variable timing cams and multi valve heads to get those performance numbers. In the case of smaller 4cyl engines, that often means a rubber band instead of a timing chain, or timing gears like our engines. All of that makes the engine capable of putting out more and more Hp per CID.
Something else we need to define is "peak horse power" verses "constant rated horse power".
Good luck getting that VW engine to hold up for more than about 60 seconds pumping out those numbers. Our diesels being a commercial design can hold steady at thier rated horsepower for days at a time (pre production testing was for several weeks).
Old Feb 27, 2009 | 12:19 PM
starmilt's Avatar
starmilt
Horsepower means nothing it is the torque that we use try pulling an 8000 pound trailer with a vw.
Old Feb 27, 2009 | 02:44 PM
axe_handle's Avatar
axe_handle
Horsepower is a function of torque multiplied by engine speed, as detailed:
Horsepower - Wikipedia, the free encyclopedia
So, if you make the same amount of torque at a greater engine speed, you will effectively increase the horsepower. This is how a diesel engine that produces gobs of torque, but does not rev high, can produce a lower peak horsepower number than a small high speed engine.
Old Feb 27, 2009 | 07:52 PM
RCrawler's Avatar
RCrawler
What model and engine are you referring to? The only VW TDI engine that is being made right now is a 2.0L with 140 hp and 236 ft/lbs.
As everyone has said, torque is where it is at. The only one that would compare is the Vortec 4.8. Those new GM engines are impressive, but they won't last under a heavy load like an IDI will. But that is comparing 25 year old technology. Look at the gasoline engines in the IDI era and nothing was making close to 1 hp per cubic inch.
The latest generation of diesels do it all. Plenty of horsepower, loads of torque and decent fuel mileage on top of it.
Jason
Old Feb 27, 2009 | 07:57 PM
dyoung14's Avatar
dyoung14
yes true they do all that, i can rebuild my engine like dave s engine for the same as a set of duracrap injectors and a repair bill
Old Feb 27, 2009 | 08:40 PM
RCrawler's Avatar
RCrawler
Costs big money to go fast...
Jason
Old Feb 27, 2009 | 08:44 PM
dyoung14's Avatar
dyoung14
yea sure does, i may not ever have the fastest truck, but im more willing to put alot of money in my old truck then in a ne computer nightmare
Old Feb 27, 2009 | 08:48 PM
David85's Avatar
David85
Jason
I remember diesel power mag had an artivle of a 4 cyl TDI build up. I think it was putting over 300Hp to the road and had to run custom connecting rods to hold all the power.
Only other engine I can think of is the touareg V10 TDI. I feel ashamed to admit that I might be intrigued by the idea of a V10 turbo diesel.
Although this 3L V6 TDI still beats the stock IDI's numbers peak for peak CanadianDriver 2009 Montreal International Auto Show Clean-diesel VW Touareg shown in Montreal
I think I'll pass on anything that has a **** water injection system though.
Old Feb 27, 2009 | 08:50 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The old speed shop line back in the 60's.
How fast do you want to go and how much money do you have?
Old Feb 27, 2009 | 09:03 PM
RCrawler's Avatar
RCrawler
They aren't as complex as you would think. People tend to make them harder to work on than they actually are, mainly because you don't see all of the components that make them function as you do with a mechanical engine. But if you have a shop manual and a little understanding of electricity and basic automotive computers, most things are easily repaired. The internet is a valuable resource when it comes to repairing and modding, just like this forum is for the IDI.
On that thought, I recently overhauled the injectors on my neighbors '99 PSD. Once I got to the valve covers to get them off, everything was pretty simple. Just a couple of different steps to follow than replacing an IDI injector. The worst part of the job was getting the air to air tubes out of the way and the fact that the engine is half buried under the dash on the Super Duty.
Jason
Old Mar 2, 2009 | 12:18 PM
ghunt's Avatar
ghunt
Hey, the 2.3 Turbo in my Thunderbird makes about 270 hp and probably 300 ft-lbs with 17 psi going through it...but I certainly wouldn't want to try to tow anything with it!
