need help today!!!
Old Feb 27, 2009 | 06:38 AM
autoxtech's Avatar
autoxtech
need help today!!!
Well i have been fighting a vibration issue around 75 and slightly around 45, , just recently installed brand new driveshaft from ford with new everything, new tires, all fluid changed, the vibration is alot more noticeable with no fuel and bed empty, when I filled up this morning the vibration changed to not as agressive but still present any help would be great , going to disney with family tommorrow and dont want to bounce 800 miles, thanks
Old Feb 27, 2009 | 07:29 AM
03_PSD's Avatar
03_PSD
do you have a lift on your truck or is it stock height?
Old Feb 27, 2009 | 07:44 AM
autoxtech's Avatar
autoxtech
stock height 2wd, only mod 6637 everything else factory ford stuff, ext cab long bed truck with top on bed
Old Feb 27, 2009 | 07:58 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
I fought a vibration issue for over a year and turned out to be the tires. I had them balanced, road force balanced etc. and never got rid of the vibration. I ended up getting a new set of tires because the old ones had gotten worn and the vibration went away. The tire guys said a belt must have let go inside one of the tires?? Dunno but it fixed the problem.
Old Feb 27, 2009 | 07:59 AM
03_PSD's Avatar
03_PSD
i'm thinking maybe getting your tires rebalanced
03_PSD's Avatar
03_PSD
Costa types faster...lol
Old Feb 27, 2009 | 08:02 AM
autoxtech's Avatar
autoxtech
it has been going on for some time now with 2 differnt set of tires, so I replaced the driveshaft just installed the other day and took on highway this morning to find i spent alot of money for nothing,
Old Feb 27, 2009 | 08:05 AM
autoxtech's Avatar
autoxtech
I have heard that the pinion nut may be loose but dont know the torque and have noticed when i changed the rear end fluid that the pinion seal is leak slightly but has never been low
Old Feb 27, 2009 | 08:53 AM
megawatt00's Avatar
megawatt00
Is your truck a SRW or a DRW. The torque specs are different for the pinion depending on the differential
Old Feb 27, 2009 | 08:58 AM
Kwikkordead's Avatar
Kwikkordead
Six speed or automatic?
I had a driveline vibration that was caused by a bad OD bearing in ZF-6.
I chased it the same way you are doing right now. New u-joints, carrier bearing, etc.
Installing a rebuilt tranny eliminated the vibration.
Old Feb 27, 2009 | 09:33 AM
autoxtech's Avatar
autoxtech
sorry it is a auto not sure about diff, 04/01 production when i do add diff fluid i have not put any addidtive for split not sure if i had a slip diff since it is 2 wd
Old Feb 27, 2009 | 09:36 AM
husker's Avatar
husker
Mine started doing the "death wobble" and it turned out to be a sticking caliper pin that was causing the drivers side brake to drag. I did a brake job and fixed the caliper pin problem and it went away. So, it can be a number of things.
Old Feb 27, 2009 | 03:47 PM
autoxtech's Avatar
autoxtech
thanks for all the help will try to post more often but of to disney and bike week at daytona
Old Oct 7, 2009 | 08:10 PM
autoxtech's Avatar
autoxtech
Well to all with a vibration . Mine is finally fixed after 2 sets of tires a couple of wheels , new u joints then a drive shaft , all fluids changed , rebalanced with a road force balancer, the carrier bearing had to be shimmed about 1/2 inch downward. there was a tsb about it some time ago with ford but not many techs know about it . Thank god that I did not have to replace the truck
