Help!?
Old Feb 27, 2009 | 12:22 AM
PaYneR's Avatar
PaYneR
yeah, air filter is fine, its like new still, ill try and get codes some how, ill change fuel filter and repost the outcome, i still dont see if being fuel like i do from the crap but the results dont seem like fuel well the jerking moms mini van did when fuel filter was gettin bad, but the black smoke? and throwing a code and then it goes?
Old Feb 27, 2009 | 12:26 AM
jkidd_39's Avatar
jkidd_39
Well without being there it's hard to tell. Pull codes will give you a much better idea
Old Feb 27, 2009 | 12:29 AM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
yea black smoke is unburnt fuel, thats why im thinking HPOP. Maybe its late and im thinking wrong, but might try unplugging the IPR and seeing if that does anything, not sure if it will tho
PaYneR's Avatar
PaYneR
what about the filter in the frame rail? or just change the top one and thats it? and i should just stick with the cps i got and say screw the recall?
Old Feb 27, 2009 | 12:30 AM
STROKIN'IT7.3
Trucks don't come stock with a filter on the frame rail, thats something added on. Try the CPS and see if that helps, it will make the truck do weird things
PaYneR's Avatar
PaYneR
ipr? sorry still new to the ford trucks, to be honest if it wasnt so cheap id have got a 12 valve :$ embarassed to say this after all the help i have got on there, but i personally like the looks :$ and love how its all mechanical
Old Feb 27, 2009 | 12:31 AM
PaYneR's Avatar
PaYneR
so only fuel filter is top of the engine? i swear there was one aswell in the frame rail but i guess im mistaken
Old Feb 27, 2009 | 12:34 AM
jkidd_39's Avatar
jkidd_39
IPR means Injector Pressure Relay.. I'm bad with those.. if you unhook it and the truck still starts then it's bad.. Thats all I know someone will chime in and explain.
I understand it's frustrating to have your truck down, i've been getting help off of here on the side of the highway from my iphone before haha..
Old Feb 27, 2009 | 12:35 AM
jkidd_39's Avatar
jkidd_39
Thats the fuel pump on the frame rail, unless someone did the hutch mod and mounted an aftermarket filter
Old Feb 27, 2009 | 12:36 AM
STROKIN'IT7.3
Directly to the right of that arrow, the two wire plug. Its on the back of the HPOP which is front and center of the top of the motor.
Old Feb 27, 2009 | 12:38 AM
PaYneR's Avatar
PaYneR
i got a blackberry myself :P it works haha, ya im just chapped cause i was supposed to see my gf this weekend which is 200km away! and my cars still in the garage due to lets say more then enough snow and colder then cold -30c overnight its calling for , well i think dads gonna buy the napa code reader for me hopefully it works... it could be plugged fuel filter, ah is there a sock like a screen sock in the tank? in the pickup line?
Old Feb 27, 2009 | 12:39 AM
PaYneR's Avatar
PaYneR
ah pump is what i was thinking, thanks jkidd_39, kinda late brains asleep im assuming its the 1st of 2 pumps? and t wouldnt need to be changed would it?
Old Feb 27, 2009 | 12:40 AM
  #28
PaYneR's Avatar
PaYneR
so i unplug that strokinit? and try and turn it on? also someones engine valley is a tad like mine, nice and dirty :P
Old Feb 27, 2009 | 12:43 AM
  #29
STROKIN'IT7.3
Yes and see if it helps. If it helps, it could point to that. Also, on edit to that post, its to the LEFT of the arrow, kinda hidden down in there.
Its that big brass piece. Thats a side view of the hpop
Old Feb 27, 2009 | 12:44 AM
  #30
PaYneR's Avatar
PaYneR
i unplug from the black plug there above the brass part?
