Door rattle
Old Dec 12, 2005 | 12:42 PM
90xlt4x4's Avatar
90xlt4x4
Door rattle
So yesterday on the way to work I noticed my driver's side door has an annoying rattle. I checked freeplay with the door closed in relation to the passenger door, and there is about 1/2-3/4 inch of play towards the cab. The door closes and opens fine, except for this closed rattle. From the inside, I can also push out on the door enough to see between the door and weatherstripping. The door mounting screws are tight and the door appears to be properly aligned. Any ideas?
Old Dec 12, 2005 | 01:20 PM
Lazy K's Avatar
Lazy K
Is the door seal in good condition? Sounds like a lot of play for a seal in good condition. You could try loosening the door keeper on the door pillar by rotating it anti-clockwise until loose and moving it towards the interior as far as it will go, then tighten. This should take out at least some play. Also check the door hinges by lifting the door at the handle edge, if loose replace hinge pins or hinges.
Old Dec 12, 2005 | 01:28 PM
Roushians's Avatar
Roushians
i got a annoying rattle out of no-where on my truck. It sounds like metal on metal clinking. I discovered that it's my aftermarket window vent, the adhesive seal let go, and it flaps and slaps the door. It creates a sound of which you woudn't think it would cause .
Old Dec 12, 2005 | 03:26 PM
skyfox10's Avatar
skyfox10
my driver door also rattles, i've had the door aligned maybe 4 times in the trucks life, because the door was having issues closing easily. recently it got this bad rattle, i noticed that the mirror assembly seems easier to move, the exterior part of the door actually flexes when i push on the mirror. i'm wondering if something came apart inside of the door. this is just personal observation. i'd be interested to know if you notice the same thing.
Old Dec 12, 2005 | 03:30 PM
quicklook2's Avatar
quicklook2
skyfox, you have a loose bolt that hold the mirror on the inside part of the door. remove plastic panel and you will see it. this is for the small mirrors.
Old Dec 15, 2005 | 07:01 PM
skyfox10's Avatar
skyfox10
thanks, i'll check it out
Old Dec 15, 2005 | 10:57 PM
handyman43358's Avatar
handyman43358
Quicklook is right, I've seen this many times. It gets annoying to hear it rattling lol.
supercrewser1751
2009 - 2014 F150
21
Mar 23, 2016 06:46 PM
quincyj34
18
Apr 10, 2014 07:10 AM
jlouki01
Jan 21, 2007 08:02 PM
damone
Jan 22, 2005 10:21 AM
bkaeding
1997 - 2003 F150
Apr 24, 2004 09:26 PM
