offy Intake Ebay
Old Feb 27, 2009 | 10:31 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Try as I might, I could not find a marine reverse-rotation firing order anywhere with Google.
Anyone actually have some data about the firing order? (just curious)
Old Feb 27, 2009 | 11:37 PM
obey_your_master's Avatar
obey_your_master
I have found a handy little diagrahm on marine 427 stuff. Here's the link:
http://img.photobucket.com/albums/v4...27valveadj.jpg
Kinda interesting stuff on chris craft engine specs!
Old Feb 27, 2009 | 11:45 PM
Madathlon's Avatar
Madathlon
Old marine specs are hard to find, Olny reason I know is I grew up working on them, Parents own a large marine back east. And I had a Pair in a 40ft Chriss craft cruiser. Reverse rotation is good for boats with 2 engines as it counters torque steer
Old Feb 28, 2009 | 12:01 PM
krewat's Avatar
krewat
I definitely saved that image
Doesn't clear up why that intake is a dual-plenum with each plenum service one complete bank. The firing order for the "right hand" rotation engines are still not side-to-side.
Guess it doesn't matter on an engine that's going to sit at one RPM for long periods of time like a boat motor.
Old Mar 2, 2009 | 02:53 PM
seven up's Avatar
seven up
Anyone wanting information about the marinized 427 may find the needed specs at the Chris Craft Commanders Club. The 427 was used often in the Commander line.
Old Mar 6, 2009 | 09:54 PM
bluesky636's Avatar
bluesky636
Originally Posted by Bear 45/70
That is NOT a dual plane manifold. This manifold even has the exhaust crossover which is not desireable either. It is a SINGLE PLANE not a dual plane manifold and for his aplication is going to hurt low end throttle response and torque. It is worth nothing to him.
I have an Offy single-plane intake on the 390 in my 64 Galaxie. I have a 625 cfm Road Demon carb on a 1/2 inch, 4-hole spacer with an RV cam. The beast has great low end torque and throttle response. The 3-on-the-tree manual and 3.00:1 rear axle are what slow her down. Punch the throttle in second gear at about 1000 rpm and she will pin you in the seat.
Old Mar 6, 2009 | 09:59 PM
Bear 45/70's Avatar
Bear 45/70
Originally Posted by bluesky636
I have the exact same intake on the 390 in my 64 Galaxie. I have a 625 cfm Road Demon carb on a 1/2 inch, 4-hole spacer with an RV cam. The beast has great low end torque and throttle response. The 3-on-the-tree manual and 3.00:1 rear axle are what slow her down. Punch the throttle in second gear at about 1000 rpm and she will pin you in the seat.
Compared to what? If it is the only manifold you have run on the engine, and used drag strip times to verify the numbers, then you don't really know, do you? Seat of the pants is the biggest liar on earth.
Old Mar 7, 2009 | 02:05 AM
bluesky636's Avatar
bluesky636
I've been away for awhile because I got fed up listening to the rantings of people like you. I see nothing has changed. You are completely incapable of responding in a civil manner to someone who disagrees with you.
Since you know nothing about my car and have never driven it, on this subject I can truthfully say you are totally ignorant. And that hasn't changed either.
Buh-bye.
Old Mar 7, 2009 | 11:48 AM
Bear 45/70's Avatar
Bear 45/70
Buh-bye.
Me rant? You are the one making claims without any proof other than your rear end. Which I wasn't aware of being a precision instrument for measuring anything except you bad attitude. Your posting of non-factual and unlikely info is an example of why there is so much wrong info floating around on the net.
Old Mar 7, 2009 | 11:54 AM
krewat's Avatar
krewat
Buh-bye.
To be fair, Bear didn't say anything wrong in his first reply to you. You do NOT know the difference between single and dual plane intakes if you've never tried them both on the same vehicle and engine.
On the other hand, Bear's second reply left something to be desired in the insult department.
Keep it nicey-nice
Old Mar 7, 2009 | 12:13 PM
Bear 45/70's Avatar
Bear 45/70
Keep it nicey-nice
You are correct sir and I edited my post. Are the changes acceptable? However he did start it and I was in the mood to carry it on.
Old Mar 7, 2009 | 12:59 PM
krewat's Avatar
krewat
Perfect
XLTRat
52
Nov 30, 2016 10:12 PM
dslman1
May 5, 2010 06:38 PM
Fomoko1
13
Dec 14, 2009 02:31 PM
460
31
Feb 7, 2007 11:44 PM
padd54
May 31, 2004 07:15 AM
