Sponsored by: Real Truck
Tow hook help.
Old Feb 25, 2009 | 06:14 PM
ReAX's Avatar
ReAX
Tow hook help.
I have two ropes I carry with me, a 1 3/4 weaved and a 2" twisted cotton rope. With bowline knots, neither fit into them well. So what I am thinking of, is using two clevises to connect the loops of the 1 3/4 rope to each loop and have it run through the 2". This will give me plenty of length, but I can't find clevises I'd trust big enough to use on these ropes. I also want to do something similar near the rear hitch. So where can I find big clevises with a minimum of 20,000 static or a very heavy shock rating? Or do you have a better idea?
Old Feb 25, 2009 | 08:26 PM
F350-6's Avatar
F350-6
Check out a tractor supply type store. Tractor Supply Company - SpeeCo 3 Point Straight Clevis Pin & Clip, 1 in
Old Feb 25, 2009 | 08:32 PM
high ho silver's Avatar
high ho silver
Originally Posted by F350-6
Dido...or maybe Northern Tool.
Old Feb 25, 2009 | 08:39 PM
ReAX's Avatar
ReAX
I'll have to stop by the Farm store next time I go to town. I've looked at several places but never found anything over 8 or 9,000lbs load, which I assume is static. I am just not comfortable putting cotton ropes on a 8k lbs with clevis only rated for that much static weight. Plus I'd like one for my winch cable and get away from the hook.
Old Feb 25, 2009 | 08:43 PM
F350-6's Avatar
F350-6
TSC, Northern, or any farm store should be able to fix you up. I've got a few of those just because they're big enough to fit over the drawbar on my tractor. The one I linked to has a working load of 25k#'s, so that should get the job done for you.
Old Feb 25, 2009 | 08:47 PM
1975StroppeBaja's Avatar
1975StroppeBaja
McMaster-Carr
search for "High-Strength Anchor Shackles—For Lifting" part number 3663T46 seems to be a decent size (aka, not too big!) and has a 25k pound work load limit. Little spendy though at almost $40/ea.
Old Feb 26, 2009 | 08:07 PM
nitrogen's Avatar
nitrogen
"crosby chain and rigging" any size clevis you can imagine and then some
Old Feb 26, 2009 | 08:11 PM
senix's Avatar
senix
I use alot of stuff from sunbelt rentals, bet they would have that also.
Old Feb 26, 2009 | 08:24 PM
WhiteEx's Avatar
WhiteEx
You may also want to check the telephone book under 'riggers' or 'cranes', those guys use big stuff all the time and would know of sources for them.
Old Feb 27, 2009 | 08:57 AM
elee3's Avatar
elee3
If you can't find what you want, try McMaster Carr. Search for shackles. You will recieve your order very fast.
McMaster-Carr
powerstroker88
Offroad & 4x4
47
Nov 18, 2009 12:58 AM
FTE/PARTS-GUY
13
Nov 6, 2008 02:12 PM
DaMole
19
Mar 23, 2007 02:24 PM
krol
Offroad & 4x4
May 27, 2006 05:03 PM
jdon88
Oct 13, 2003 10:43 AM
