Offroad & 4x4
Tow rope alternative?
Old May 27, 2006 | 02:47 AM
krol's Avatar
krol
I was at the marina the other day and saw some thick docking line about 2-2.25 inches in diameter and right away wondered if it would make a decent extraction rope for when I get stuck. I have straps, but they're not long enough and I have had to combine 2 or 3 straps in the past to make the proper length. If I could get this rope at a reasonal price, or even free (it it's used) how do you think it would work? I looked up marine rope on the internet and some ropes have high working ratings (lbs). Straps can get pretty expensive, so I was just wondering about your thoughts on this possible alternative.
Old May 27, 2006 | 06:51 AM
Jmudder79's Avatar
Jmudder79
I've seen lots of people use that stuff as extraction rope before(I live right on the Jersey shore, lots of marinas, boat places, etc.). It seemed to work fine. I don't know the specifics of the pieces they were using, like rated weight or anything but it was real thick.
Old May 27, 2006 | 09:24 AM
rebocardo's Avatar
rebocardo
I have seen other people use thick rope and it works fine, though it was only for lighter nearly stock F-150s.
I would think the splice for the loop would be the tough thing and would have someone else do it.
Old May 27, 2006 | 10:21 AM
monsterbaby's Avatar
monsterbaby
The only disadvantage to that rope is it doesn't have the rubber band affect that nylon tow straps do, as it doesn't stretch by nature. But it's plenty strong enough to tow about anything out with, I have seen it used to pull some heavy equipment out of bad stuck situations.
Old May 27, 2006 | 12:35 PM
krol's Avatar
krol
Thanks for the replies, I'll see what comes of it and post my results.
Old May 27, 2006 | 01:49 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
i prefer straps myself....i like the soft stretchy affect
Old May 27, 2006 | 03:30 PM
69cruiser's Avatar
69cruiser
that rope is some strong stuf depending on the thickness of it but it pulled my superduty out of the canyon when i sunk it last year the only draw back to it is the lifespan of it depends on how you take care of it and how much mud it see's just get some shackles and start pulling
Old May 27, 2006 | 04:43 PM
KubotaOrange76
i always try to throw my rope/straps in the washer after i get them covered with mud
supposedly the grains from the dirt will stay in and grind awway at the threads with use?
Old May 27, 2006 | 05:03 PM
69cruiser's Avatar
69cruiser
i know alot of the guys wash them out and dry them in the shade after playing in the mud the one thing i heard is the average lifespan of them is about a year of every weekend use they also buy them by the spools comes out alot cheaper get a couple guys to go in on it split the cost but the shackles are the expensive ones
abe
May 19, 2016 10:33 AM
cheezit
Nov 11, 2015 10:39 PM
TomBrooklyn2
25
Apr 29, 2015 09:34 PM
fixnair
Flathead V8 & Flathead 6
Mar 31, 2012 11:07 PM
AeroDuke
Aerostar
Apr 27, 2006 09:31 PM
