I need a BJ!!
Old Feb 25, 2009 | 07:44 PM
BigBlueOx's Avatar
BigBlueOx
well a BJ is a BJ right.
Old Feb 25, 2009 | 08:23 PM
rockin300's Avatar
rockin300
i thought it would be something nasty with a title like that,ox is right a bj is a bj even if its a ball joint or two
Old Feb 25, 2009 | 08:45 PM
rangermike's Avatar
rangermike
My BJ's are never sloppy.....
Old Feb 25, 2009 | 09:00 PM
94XLTFLAREI6's Avatar
94XLTFLAREI6
I like the humor here....
My lower ones were trash last spring/summer....with 135000 miles....
I got Moog w/grease fittings....I did the uppers at the same time, just cause I would have everything apart. Did new front brakes and turned rotors also... a two fer.... roll on....
andy22285's Avatar
andy22285
D44 Front Maintenance Kit, WITH GRANDE JOINTS!
get this and do it all while your in there, not a bad price, and you can forget about it all for a couple thousand miles.
Old Feb 25, 2009 | 09:02 PM
rockin300's Avatar
rockin300
my nethier
Old Feb 26, 2009 | 11:40 PM
9.ford.5's Avatar
9.ford.5
hahahaha thats one way to get a good response...ya gotta get the high quality BJs man...the cheap ones are always sloppy...who likes a sloppy BJ?
BTW: i meant BALL JOINTS you sickos! jeeeez! LOL i almost pissed myself reading this thread though
Old Feb 26, 2009 | 11:59 PM
Beamed's Avatar
Beamed
go with the moogs from carquest there the best that i had so far also the longest lasting on my buddys f150 prerunner and i know those things take a beating and far as a press u dont have to have one just a big socket that fits on the out side of the ball joint and a hammer just be sure to mark ur camber shims before u loosen everything so it isnt to bad gettin to the alinment shop
Old Feb 27, 2009 | 12:17 AM
jr32560's Avatar
jr32560
not a bad idea if the ball joints come with grease fittings-the stock ones don't!
Old Feb 27, 2009 | 05:45 AM
4020FarmBoy's Avatar
4020FarmBoy
Moog is the best. You can get them and do it once, or get cheapest Advance Autos with a "warranty" and do it again down the road. I prefer do it once.
I would recommend locating a ball joint remover/installer tool makes the job got a lot easier and probably not a bad idea to do outer u joints while you are that far in.
Took me and my friend who is a mechanic about a day but we dont try to move to fast.
Old Feb 27, 2009 | 12:42 PM
qman's Avatar
qman
Originally Posted by 86F150302
I get my BJs from Autozone. Manager hooks me up...
What's her name?
What the????????????
Old Feb 27, 2009 | 01:51 PM
waynaferd's Avatar
waynaferd
Now, I like the kit from Jeff's Bronco Graveyard, except, of course, it says OEM balljoints....I've got under 50K miles on the truck so I can't imagine I need new bearings, and the U-joints were tight when I installed the lift, and those are cheap anyway to replace.
So would I be better off with OEM ball joints, or greasable Moog's? That's pretty much the determining factor in getting the JBG kit or just what I need.....Thanks!!
Old Feb 27, 2009 | 02:12 PM
  #28
qman's Avatar
qman
Definitely always get greasable if you will actually grease them. My neighbor has a 1972 Chevy van with 250Kmi on it and he has always greased all zerks whenever he does an oil change and he has never had to replace anything in his linkage. All of his joints are still nice and tight. I've always wondered though how much he's spent on grease over the years. Either way, it just goes to show you how effective preventative maintenance can be.
If you're not committed enough to grease them then get em sealed.
Old Feb 27, 2009 | 11:55 PM
  #29
9.ford.5's Avatar
9.ford.5
yeah when get greasable then EVERY time you get er oil changed wash it up good first then grease everything while your under there thats what i do...theres more grease points on 1 big rig then there are on probly 6 of our trucks so i figure thats gotta play into why their joints rarely ever need to be replaced and when they do its cause they are UNDERGREASED
Old Feb 28, 2009 | 05:03 AM
  #30
cbslayer's Avatar
cbslayer
i just replaced this past summer upper and lower joints on both sides and i used the press its a little tricky to use but it makes the job so much easier i have done them without a press using a plumbers torch and a sledge hammer and let me tell you the press is the way to go and i whole heartily agree while its tore apart replace the universals as they probably have never been changed (like mine) mine were trashed and they never made a sound it would really suck to have to tear it all back apart for 3 universal joints that cost me 40 bucks
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
