High Idle Mod?
Old Feb 25, 2009 | 04:23 PM
powersmoker96's Avatar
powersmoker96
High Idle Mod?
Is there a way to increase the idle speed without using a chip or programmer? I know you can do it on the newer 6.0's but haven seen if it could be done on the OBS trucks?
Old Feb 25, 2009 | 04:29 PM
cowmilker08's Avatar
cowmilker08
They say with a 140v idm you'll get slightly higher idle and a much smoother idle at that, but i have yet to do it.
Old Feb 25, 2009 | 04:47 PM
Cuda_jim's Avatar
Cuda_jim
The 140 IDM won't increase the idle but it will smooth out the idle the PCM calls for.
You can make one of these:
North Texas Power Stroke Association - DIY AIC Mod
or you can get a AIC that comes on Sooper Dooties. There should be a plug for it under the dash.
https://www.ford-trucks.com/forums/a...0&d=1224500563
More info Here:
https://www.ford-trucks.com/forums/7...contoller.html
Old Feb 25, 2009 | 04:50 PM
KevinC.'s Avatar
KevinC.
140v IDM didnt help my idle speed at all.
Cuda_jim's Avatar
Cuda_jim
Or you can use my High Idle Mod, "HIM". It's my snow scrapper propped against the seat and wedged against the Go Pedal.
It's infinitely adjustable and almost free. LOL!
I like dual-purpose tools
Old Feb 25, 2009 | 05:25 PM
KevinC.'s Avatar
KevinC.
Why are you wanting to raise your idle? Is it just idling low or are you wanting a high idle for warm up times or running equiptment?? When I shimmed my FPR and cleaned the return screen it raised my idle from about 500rpm to around 750.
Old Feb 25, 2009 | 07:23 PM
powersmoker96
well mostly for a faster warm-up, I use alot of electrical demanding things everyday for work, like a winch, inverter lots of lights when i go on fire runs and leave the truck running at the scene with all the goodies on
Old Feb 25, 2009 | 07:55 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
I saw in you signature that you have a TW chip, I dont know how many positions do you have, but you can send it to Tony and reburn one of the position to HIGH IDLE, and till I know is for free.
Old Feb 25, 2009 | 10:40 PM
JethroF250's Avatar
JethroF250
i shove a screwdriver behind the pedal
Old Feb 26, 2009 | 07:52 AM
Neal 97 250's Avatar
Neal 97 250
TW Hi-idle is 1100 RPM. Not high enough IMO. I want it a bit higher.
Old Feb 26, 2009 | 08:11 AM
powersmoker96
yeah 1100 rpm doesnt really cut it too well, but just dont want to buy a ford aic controller, im sure they are really expensive!
Old Feb 26, 2009 | 11:06 AM
yoslick's Avatar
yoslick
Keep en eye on EBay for a used AIC, got mine about 2 weeks ago for $65 and it is great!!
Slick!
Old Feb 27, 2009 | 11:33 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Slick!
How many RPMs does that AIC produce?
Old Feb 27, 2009 | 11:45 AM
Cuda_jim's Avatar
Cuda_jim
2500 RPM, way faster than needed IMO.
Old Feb 27, 2009 | 11:59 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
So 1,100 are to low and 2,500 are to fast, what are the good RPMs for High idle?
Im only curios because I have the high idle in my TW chip, and really I dont need it for warm up in my town, only when at idle I need the A/C. or something else, like inverter or so.
