High Idle Mod?
Old Feb 27, 2009 | 12:09 PM
superduty4x4's Avatar
superduty4x4
Originally Posted by Cuda_jim
2500 RPM, way faster than needed IMO.
The higher end AIC's are adjustable... about 1300 is what you want for most things.
AIC's came in some OBS's too, they weren't exclusive to the SD.
Old Feb 27, 2009 | 12:25 PM
yoslick's Avatar
yoslick
Just checked mine to be sure, mine is the older AIC, no digital display, only 4 buttons, pretty simple, push the charge button/set the parking brake and it brings the engine up to 1200 rpms to provide 14.1 volts at the alternator, as more demand is required ie: heater, AC, lights, glow plugs etc.. it will increase the RPM to a maximum of 1800 rpm's to keep the voltage/alternator at maximum out put... The other button is for PTO attachments and is set for 2500 rpms which is right dead center the torque range to provide necessary power to attachments like winches and hydraulics.... The newer AIC's with digital display allow you to set your rpm at any setting you want but they go for more coin on ebay as well..
Slick
Old Feb 27, 2009 | 02:14 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Slick
Thank you, I got the idea.
Old Feb 27, 2009 | 04:07 PM
WALJON's Avatar
WALJON
I have an AIC and the min rpm is 1300 rpm for what reason I don,t know but even 1300 rpm seems a bit low 1400rpm is perfect for warm up in the morning the charge protect option is nice too
shortbed97
Jan 29, 2012 11:40 AM
79bigblock
Nov 18, 2010 10:28 AM
rabidranger
Dec 5, 2002 10:37 AM
tomucen
Aerostar
Jan 8, 2002 10:11 AM
robie
Jul 18, 2000 09:46 PM
