High Idle/PTO Contoller ?
Old Oct 17, 2008 | 12:13 AM
foxracing0934's Avatar
foxracing0934
My wrecker for work has the electonic idle controller, little black box that shows a digital RPM and has a big FORD button. Well it wasnt hooked up because i was told it was broken, so i tried it anyways and after cleanning the e-brake pedal sensor got it to work as a idle controller. My question is how does this controller read the rpms? Because it will not show up in the wrecker, but it will in my truck. Any thoughts would be great, Thanks
Old Oct 17, 2008 | 05:16 AM
Cuda_jim's Avatar
Cuda_jim
Let me get this straight:
It controls the idle on both trucks? but the tach only works on your truck?
Does the tach work on the wrecker?
There is more than one hi idle/PTO controller or
APCM's (Auxiliary Powertrain Control Module).
The APCM may not be compatible from year to year
or from a Cali/Van to an F series or from an Auto to a Manual trans.
You need to verify which controller is used with :
PCM 'catch-word' tag may be located on the vehicle A-pillar or on the PCM itself.
catch-word for a all manual trans (SOD4)
catch-word for an Automatic F250, F350 & E350 (TEE5)
F450's are (PRY4)
There are 2 for 1995 only, one with CC and one w/o.
Trucks prior to 95 need to be reprogrammed to OBD2
APCM gets the Tach signal from the PCM.
IIRC the PCM uses the CPS signal for the Tach?
The Tach signal comes from different pins on the PCM from a Cali/Van PCM to
a 49 state PCM so that may be the differences, IDK.
The APCM gets it's signal(s) by piggybacking on the PCM through the OBD2 connector wires T/O and PK/LB. The W/P is power and BK is ground
F series Power (W/P) comes from:
fuse 18 under the dash 96-98
Fuse 19 for a 1999
E series power comes from the ignition switch.
Old Oct 17, 2008 | 06:43 PM
foxracing0934
Ok, well both trucks are 1997 F-350's. Mine is and auto and the wrecker is a ZF. The tach works in the wrecker on the gauge cluster but not on the Controller, and the wrecker is not a Cali truck and nor is mine. When it is plugged into my truck the rpms will show up on teh controller but they are very slow to move, and they are really jumpy. i.e. it will go from 780-1200 and nothing in between.
Old Oct 17, 2008 | 07:38 PM
BlueMule's Avatar
BlueMule
I don't know if this will help or not but here's the manual for the controller.
APCM - Introduction - 1994-1997 Power Stroke FAQ
Old Oct 18, 2008 | 01:39 PM
foxracing0934
No that site didnt have anything about how or where the APCM gets the RPM signal from, thank you though.
Old Oct 18, 2008 | 07:34 PM
WALJON's Avatar
WALJON
Sounds like maybe it is broken this could be the reason why it was unplugged
Old Oct 19, 2008 | 06:51 PM
79_250RangerLariat's Avatar
79_250RangerLariat
I can't get my digital AIC to read RPM's in my parents 97, but it reads in my 97. Friend had trouble with his not reading till he put a chip in.... who knows
Old Oct 20, 2008 | 06:03 AM
Cuda_jim's Avatar
Cuda_jim
See if this helps. It shows how to program the AIC/APCM
File Type: pdf
lil'ford
21
Jun 19, 2015 03:31 AM
71dusterdan
General Automotive Discussion
Dec 29, 2011 01:46 AM
havi
47
Oct 1, 2011 03:24 PM
SixGunCaliforniaKid
Oct 1, 2011 01:48 PM
Wrecker
User Gallery & Picture Display
Jan 2, 2005 05:13 PM
