Spark plug melted?
Old Jan 19, 2010 | 01:06 PM
dcpump's Avatar
dcpump
Spark plug melted?
I have my pick up at the shop and they are saying the spark plug has melted into the top of the cylinder and now the cylinder has no compression. What would cause that?
Old Jan 19, 2010 | 06:47 PM
svt2205's Avatar
svt2205
Was that a factory installed plug or were you running an aftermarket (OE Replacement)?
Old Jan 19, 2010 | 07:32 PM
bridge's Avatar
bridge
Sick 'n Tired
Eh? That doesn't make any sense. Need some specs. 5.4L or 4.6L? How many miles? Year?
Old Jan 19, 2010 | 07:47 PM
Warbird Mechanic's Avatar
Warbird Mechanic
Sounds to me like preignition has occured. Typical symptoms are melted electrodes on the spark plugs. The spark plug insulators are white, but may be dirty due to misfiring or flying debris inside the combustion chamber that can lead to engine damage. Things your shop needs to check for are correct plug heat range, over advanced engine timing, lean fuel mixture, insufficient engine cooling and lack of lubrication. Hope this helps!
Jim
Old Jan 20, 2010 | 02:02 PM
EBTDM's Avatar
EBTDM
WTF!!!!
Post pictures and I might believe it actually might happen.
Add it up, Spark plugs melting is not going to happen.
Porcelain cannot melt, electrodes burn off to carbon, stainless heat shields have a higher melting point than aluminum heads & blocks, piston will burn through before aluminum will melt.
At this point, I can only believe that the term melting is being used wrong. I do believe and have rebuilt many burn throughs over the years.
Burn throughs will happen from too far advanced or retarded timing and/or repeated pre-ignition.
JohnRayII
28
Jan 7, 2017 11:06 AM
Bluegrass 7
1997 - 2003 F150
Jul 5, 2016 09:39 PM
4477rick
2004 - 2008 F150
Jun 20, 2016 02:11 PM
1961econolinePU
May 5, 2016 03:07 PM
nothercrash
Mar 8, 2011 01:02 AM
