New 460ci
Old Mar 4, 2009 | 09:01 PM
  #31
Kiwi Petrol Head's Avatar
Kiwi Petrol Head
Monsterbaby - how does this sound -
Inlet manifold
Weiand Stealth Intake Manifolds
Part Number: WND-8012
Intake Style: Dual plane
Basic Operating RPM Range: Idle-6,800
Cam
Product Line: Edelbrock Performer RPM Cam and Lifter Kits
Part Number: EDL-7167
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,500-6,500
Duration at 050 inch Lift: 234 int./244 exh.
Advertised Duration: 290 int./300 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.556 int./0.581 exh. lift
Lobe Separation (degrees): 108
Carb -
Edelbrock
Part Number: EDL-1407
Number of Barrels: 4
Carburetor Flange: Square bore
Choke: Manual
Secondary Type: Air valve
Fuel Inlet: Single
CFM: 750
Ford Kickdown: No
Throttle Linkage Type: Universal
Carburetor, Performer, 750 cfm, 4-Barrel, Square Bore, Manual Choke, Single Inlet, Silver, Each
Do a nice port and polish on the head as well as a free breathing exhaust
Keep it below 5500~6000rpm and hopefully drag out the 400+ reliable horses.
What do you think?
Old Mar 5, 2009 | 07:50 AM
  #32
monsterbaby's Avatar
monsterbaby
Thats a good intake and one I recommend a lot, I would choose a different cam though. something in the comp cams xtreme energy series cams like the XE262H would get you in the 400hp range and still be dependable I would think, or maybe even step up to the xtreme 4x4 X4270-H cam (you will need to replace the spring on your heads for those) either one of those should get you where you want to be.
Old Jun 4, 2009 | 06:04 PM
  #33
Kiwi Petrol Head
I have been researching cams as it's time to order parts and would appreciate ayou opinions on the two cams below - the XE262H cam and the Lunati 61602 as well. Very similar in the durations -
Lunati
Part Number: LUN-61602
Basic Operating RPM Range: 1,400-5,700
Intake Duration at 050 inch Lift: 219
Exhaust Duration at 050 inch Lift: 227
Duration at 050 inch Lift: 219 int./227 exh.
Advertised Intake Duration: 262
Advertised Exhaust Duration: 268
Advertised Duration: 262 int./268 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.540 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.552 in.
Valve Lift with Factory Rocker Arm Ratio: 0.540 int./0.552 exh. lift
Lobe Separation (degrees): 112
Compared to - comp cams -
Grind Number: XE262HCam Style:
Basic Operating RPM Range: 1,300-5,600
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 218 int./224 exh.
Advertised Exhaust Duration: 270
Advertised Duration: 262 int./270 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.513 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.520 in.
Valve Lift with Factory Rocker Arm Ratio: 0.513 int./0.520 exh. lift
Lobe Separation (degrees): 110
There seems to be little difference in the durations but the Lunati has more lift and a larger LSA - will that make much difference? - What one would you recommend considering it will be going in a truck (F-150 about 4500lb vehicle weight, lowered, weekend drive/show)?
I am also moving toward the Edelbrook air gap RPM manifold as the temps here never vary from between 75F and 90F. I'm looking forward to getting the parts ordered to get this build going... I will get as much info as possible from The Mad Porters website for porting the heads - especially the exhaust side - as everyone recommends him highly...
Your thoughts are very much appreciated guys... Thanks
Kiwi
Old Jun 4, 2009 | 07:55 PM
  #34
monsterbaby
Either 1 would work good for you, the higher LSA would increase the dynamic compression a little bit and the extra lift will require a little better valve spring but it's not way out of range.
SCBudman
Electrical Systems/Wiring
Jan 22, 2024 10:49 AM
PintoGuy
17
Jun 22, 2015 08:58 PM
nonrev321
Feb 14, 2015 03:44 AM
81and76F.S.
Feb 10, 2015 11:32 PM
ken hinson
New Member Introductions
Nov 18, 2007 12:20 AM
