I was wondering about drilling those ports out myself. I have never heard of that before I watched that video and was wondering if anyone was doing it.
To be honest with you, through some careful thought and research it's my opinion that this mod lowers the fuel pressure unless you're up there or at WOT. I didn't need a fuel pressure guage to figure that out either. It seems the fuel port plugs that our dear friend Bill suggested we drill out, plays a role in maintaining the fuel pressure at the bowl and to the injectors. If you had a regulated return, a better fpr spring, or some other way of increasing the pressure this mod probably wouldn't be a problem for you.
As far as fuel economy, that tanked even with my SCT. According to the overhead liar (which is surprisingly accurate on my truck) I normally average 19mpg+ on the freeway and about 16.5mpg-17mpg give or take around town. The overhead liar said I went to 16.4mpg on the freeway and about 13-14mpg in town.
At WOT I had all the passing power I needed and then some, but driving around town, I had to mash the pedal more for the truck to follow it's normal shift pattern. It's almost as if my truck were saying: "push the pedal further, I need more fuel".
After I put it back the way it was last night, my truck is it's normal self again. Now all I have to do is "tip' the accelerator and it goes.
The long and short of it, your regulated return system has a way of increasing or decreasing the pressure; as long as it can do that, it's worth a shot. My advice: try the regulated return first before drilling out the fuel port plugs.
I did the standpipe mod, but your experience has me thinking of forgetting the 'restrictions' in the heads. Not worth the time, in my books.
Thanks for the insight man. I wondered if you had a stock fuel regulator or something. Makes complete sense what you said. The regulator I've got is an Aeromotive just like ITP has with their kits so the pressure can be adjusted accordingly. I know Black Widow sells a JIC fitting that you can replace that port plug with so you can feed/return directly into the fuel rail instead of at the top like most do. I just figured that since I would have most everything out of the way when working on my up-pipes, turbo, and fuel system, I'd drill 'em out for the hell of it. I'll see if I feel like it when I get in the shop tonight!
I hadn't heard of it either till the video and hadn't heard of anyone actually doing it until yesterday. There's a good possibility without any way to regulate the pressure other than stock that the same thing would happen as stated above.
BTW- I watched the pmr video this morning and you're right Pocket. Not comparing apples to apples when talking about pmr's and definately opinionated instead of factual.
Also watched the video where he's putting a WW on a turbo still on the truck. After he gets the housing off, he's talking about the oil blowby and says something like, "Oh, that's just the blowby from the engine, not bad for a 720,000 (ish) motor." I'm thinking YEAH RIGHT! And you're just now replacing the compressor wheel with nothing else done to the turbo?!?!?
So is it worth is to do the fuel filter spring mod or No? I would like to have everyones opinion.
For me, yes it was worth it; throttle response is much smoother and more responsive.
When I got on the freeway my truck just kept pulling and pulling along giving great mileage at the same time. This was in the face of a fierce headwind too!
Without the headwind headed north bound, it pulled right up an over-pass without using much of the turbo or much effort.
So whether or not you have a chip, exhuast, or whatever mods, it's worth it.
I watched that too and I thought it was funny that he said you do not need forged rods unless you going to be drag racing and that pmrs are ok for "everyday driving around town." Who ever said that they weren't?
I have a 2002 7.3 F250 changed the fuel filter and also took out the plunger thing to get more fuel etc..re-installed the heater element looked fine was very careful not to bend anthing,,,ran fine on the plug but when i parked it at work (not plugged in) it would not start. after a awhile it did..I went and added some diesel additive ,,this am started up fine. after i had first installed the fuel filter and turn key on waited then started the truck i could smell something like burning not smoke but like wires( I thought maybe since the fuel bowl was not filled all the it was just the heater element) ...havent smelled it since ...now my question did i burn out that element somehow?? would my truck run rough all the time if it was fried? should I put back that plunger inside the fuel bowl? is there another potential problem if my truck has a hard time starting not on the plug??
Have you gotten any further on this issue? I've have/had a similar deal with my truck. It gelled up back in December so I drained the fuel bowl so I could add some 911 in it. Ever since then I've had trouble getting it started, even while plugged in inside the shop (my shop's not insulated). I originally thought that my plug wasn't making a good connection at times cause it would start right up some days and other would act like the glow plugs weren't working. Started to wonder if it was a fuel issue because when I'd cycle the glowplugs several times (even when plugged in and in shop) the fuel pump is running too. So got me thinking that I was inadvertantly priming the fuel bowl when I was waiting for the GPR. If I let the truck set for several days it wouldn't start well, but if I was using it pretty regularly, it'd start fine.
I'm thinking that when I drained the bowl and then closed the drain valve, it didn't seal completely and was seeping out when it wasn't pressurized. Then the other day I was under the front of the truck and noticed that my crossmember, tie rod, and the block below the drain tube were damp as if fluid had been covering them.
So... after all this you might check to make sure your drain valve is closed properly and it's not just bleeding the fuel pressure off when the truck is parked.
Well, I'm with Toreador on the drilling of the ports. And I also know why the powerstrokehelp guy only drilled out one set of the holes and not both. I'll be replacing one of mine as well!! I thought Id just drill out both sets of holes, but it weakens the area so much that it actually bent the body of the port when the drill caught. So that one is ruined. and I'll be getting that replaced before I finish it.
I definately say that the drilling of the ports is a complete waste of time for our trucks. At least is was for me cause of the setback in time and having to replace one of them.
