the y pipe on a 93 ranger
Old Feb 24, 2009 | 04:50 PM
danny_g_76's Avatar
danny_g_76
I have a 93 ranger with the 4.0 mtx. COming out of the y pipe it isnt round. I am looking to see if any one has ran pipe off of this. I cant fit anything on there. Is there maybe a company that makes something that works. I dont want to run true duals so I need to keep the y pipe.
Thanks
Old Feb 25, 2009 | 12:24 AM
Bear River's Avatar
Bear River
Former ******
Ok, why are you try to mess with it, can you further explain what it is you are trying to do?
Old Feb 25, 2009 | 12:47 AM
cooljman1's Avatar
cooljman1
what I did was made a plate that attached to the flange on the Y then I squeeshed down the end of a 3" pice of exhaust pipe and welded it to the plate.
Old Feb 25, 2009 | 08:18 AM
Bear River's Avatar
Bear River
Former ******
There may be adapters out there, but can you please describe what kind of system you are trying to make?
Old Feb 25, 2009 | 11:54 AM
racsan's Avatar
racsan
sounds like he wants to do away with the converter and run straight pipe in its place. its much easier to use the converter as a mounting point, if its plugged, a 4' section of thin wall 1" pipe will easily punch a hole through the catalyst, do it a couple of times and you'll have a 2" passage with the converter not hollowed out, it will still look stock if you have a visual inspection to deal with, may or may not pass the "sniffer' check, but you may not have that to worry about in your area. i never said it was legal, but i will say it works.
Old Feb 25, 2009 | 11:18 PM
Hank85713's Avatar
Hank85713
guy that did my system made a piece of tailpipe fit by forming it to fit the oval and then welding it on used the flange from the cat to the Y pipe to bolt onto. Not a big deal took him about 20-30 minutes of fiddlin with to get done.
Old Feb 26, 2009 | 09:16 AM
danny_g_76's Avatar
danny_g_76
The cat is rusted and I am looking to bypass it. It will still pass inspection. They don’t care about emissions here older than 96. So I want to just put in a piece of pipe where the converter is. It is an after market cat so there are no flanges it is just welded on. I can bend a pipe to fit and weld it but I would like (if they make one) a piece that works.
Old Feb 26, 2009 | 10:08 AM
Bear River's Avatar
Bear River
Former ******
The cat is rusted, dude, thats stainless steel. Yeah it tuns brown and pits, but t should take a very long time to really rust. If its not plugged, I would just leave it.
So you are saying the stock flanges are gone? If thats the case, we have pre-formed y-pipes that may work, but your circumstances need to be perfect to use them. They are intended for systems built from scratch.
Thumper19
Jun 8, 2012 08:56 AM
mihulka3
Nov 18, 2009 01:39 PM
SuperKram
18
Dec 31, 2008 09:07 PM
powerman6.0L
Oct 24, 2007 07:42 AM
FX4Range R
Feb 28, 2004 10:56 PM
