Sponsored by: Real Truck
Wierd Steering Problem
Old Feb 25, 2009 | 01:05 PM
bubbasz1's Avatar
bubbasz1
Originally Posted by dchamberlain
While I would agree that a front axle u-joint COULD be so frozen as to make it difficult to turn the wheel, I find it highly unlikely that one would be so. If it were, engaging 4WD would likely be a bit catastrophic, and that problem would have been discovered by now.
We could on about this for ever, if in fact it was seized putting in in 4wd probably would not catastrophic because> a, the other wheel would turn, b. you would get some wheel shake as they they probably aren't froze solid.
Old Apr 3, 2009 | 11:15 AM
deeznuts822's Avatar
deeznuts822
Just because the truck is not in 4x4 has nothing to do with anything,the u joints in the axle allow the wheels to steer,pivoting when the wheels turn left and right. If they didnt have anything to do with steering the front axles would be like rears,no u joint. An easy way to tell if its actually the u joint is to jack up the front of the truck,lock the hubs and turn the steering wheel full left or right and try turning the tire one full turn. If it binds its the u joints, if turns free then its not. on my old 88 in 4wd with a bad joint it would turn then act like i locked the ign and stick in full turn
Old Apr 3, 2009 | 11:49 AM
RRranch's Avatar
RRranch
I heard no mention of an alignment after you replaced the ball joints. Did you get it aligned after you did it? The symptoms you describe are classic caster way out of whack symptoms.
Caster is what returns your steering back to center. Caster is mostly what keeps it driving straight down the road when you let go of the wheel.
Old Apr 3, 2009 | 01:27 PM
dgsone's Avatar
dgsone
Sure did have alignment checked. The strange thing is this condition doesn't happen all the time. Yesterday I drove about 60 miles and it didn't act up once. Today it did it 3 or 4 time just in my 25 mile drive to work. I can't figure it out. The only other thing I can come up with is that the front calipers are sticking sometimes.
Old Apr 24, 2009 | 12:41 AM
EXv10's Avatar
EXv10
Read my post in ex section............exv10
Old Apr 24, 2009 | 06:49 AM
DetailerDave's Avatar
DetailerDave
I have but one question: How would any frozen shaft U-joints NOT be noticed when replacing ball joints, as the shaft has to be removed to change ball joints?
Old Apr 24, 2009 | 08:57 AM
joesuper's Avatar
joesuper
Trailering
I had the same problem when I first replaced my ball joints. I use Moog parts and spindle on one side was very tight. After I torque it onto the axle yoke I could barely move it by hand. After 1,000 miles or so I don't have any issues any more.
2004 F250 4x4 Crew Cab
Old May 8, 2009 | 12:47 PM
RUNVS's Avatar
RUNVS
Have the same issue with me 2002 F-250 with 80K miles. If I make a sharp right turn, the truck will continue to track to the right. If I turn left it will continue to track to the left.
Yesterday I felt a "wobble" in the steering wheel. The kind you might get when you have 4-wheel drive engaged and drive a slow turn on asphalt.
Took it to my buddies shop and we jacked it up. Front tire does NOT wobble. I thought it might if it were wheel bearings. However, if you grab ahold of the front right axle shaft u-joints and "wiggle", you can see movement where the axleshaft comes through the bearing and seal that is on the knuckle.
I presume there to be a bearing in there for the axle-shaft to spin and I'm thinking this is worn out.
However, I'm not sure the issues are related. I had all ball-joints replaced about 15k-20k miles back.
Any other ideas????
Old May 8, 2009 | 09:03 PM
EXv10's Avatar
EXv10
Originally Posted by bubbasz1
Sorry but I don't agree, if the joint is seized it will hold up the turning of the hub because it is going through the hub, supported by bearings. If it is stuck in position by a frozen joint when you try to turn against the frozen position it will play havoc with your steering. Had the problem on my ex Bronco, if the seized joint turned at all it would grossly affect how straight the truck went and how it turned.
I agree with bubbasz1. Also; it's not necessarily a u-joint problem because the only get a third of the force and rarely used so rarely go bad. The friction on the stub shaft can play havoc with your steering. It can be the bearings or in my case someone left 2 nuts off the knuckle a year ago.
Old May 11, 2009 | 11:09 AM
RUNVS's Avatar
RUNVS
Got mine in the shop on Saturday. The front right lock-out hub (I do NOT have ESOF) shredded itself. I appears that the pieces that were laying there jammed up and caused the hub to "lock" and therefore the tire was turning the front right driveshaft.
Pulled out the guts of the lockout and runs fine again. Now looking for aftermarket lockouts. Anyone have any suggestions??
Old Dec 11, 2009 | 08:27 PM
whats a tundra's Avatar
whats a tundra
can somebody please post a pic of pittman arm position with steering wheel straight ahead? thanks 1993 150 twin beam 2 wx4 thanks
Old Dec 11, 2009 | 10:51 PM
Pinky Demon's Avatar
Pinky Demon
Originally Posted by Sooper-Doodie
Actually, it is correct as there is NO mechanical link driving the axle shaft when the hubs are unlocked, just friction. Any motion from the knuckle is either going to cause the u-joint to slow down or speed up to get past the "binding" point.
If the u-joint is siezed, the axle shaft will adjust speed when the knuckle is moved as its not mechanically connected in the hub if the hub is unlocked. All in all, if the hubs are verified "unlocked" you won't feel any feedback from them if they are siezed or not unless it's in 4x4.
Wrong. I just replaced my 2 front U-Joints. The truck would quickly jerk back to center when turning a corner, or sometimes, would bind and cause the steering wheel to violently jerk back and forth. I started with the PS Pump, replaced the Gearbox, added a dual steering setup. Finally ended up at U-Joints. No problems to this date after replacement. This was in 2wd, with hubs UNLOCKED.
OP, check them U-Joints man.
Old Dec 11, 2009 | 10:52 PM
  #28
Pinky Demon
Warn Premium Locking Hubs. They supply Ford with the OEM hubs anyway. Probably the best locking hubs on the market.
Old Dec 13, 2009 | 10:18 PM
  #29
EXv10's Avatar
EXv10
Before everyone makes claims about wether or not their u-joints are causing havoc with their steering while in the unlocked position they should determine whether or not the joints are actually turning while in that position. Under normal conditions they will just sit there and go along for the ride and settle into a horizontal friction free plane to allow for turning. Under abnormal conditions (such as friction on the stub shaft) they can turn while in the unlocked position which can play havoc with your steering if the joints are binding at all. You can mark them to determine whether are not they are turning.
Old Dec 14, 2009 | 05:13 AM
  #30
bubbasz1's Avatar
bubbasz1
It actually doesn't take much for the axle to turn while in the unlock position but the real kicker of a bad joint is when you turn the joint will catch causing the steering to be choppy or catch, in the end you really just have to turn the joint while in the free position with the wheels turned slightly and you will know if the joint is bad.
