Buffing out paint
Old Jul 11, 2002 | 04:34 PM
Chuck 6083's Avatar
Chuck 6083
From: Where they take the census by counting the appliances on the front porch and multiplying by five
Buffing out paint
Hey guys,
I was wondering what the procedure would be to bring back faded paint? I don't believe my truck need a paint job as it looks pretty good when washed (suits me). But I would like to make it shiny again. Do you go with the rubbing compound? Do I need a buffer? It is the original factory paint ('83) but it doesn't appear to be thin anywhere except the top of the cab and you can't see that unless you're in the bed. Any help would be appreciated!
Thanks,
Chuck
Old Jul 12, 2002 | 07:00 PM
rgillies's Avatar
rgillies
Buffing out paint
I have had great result with this process, but I am not an expert:
You will first need to "Clean" the paint which will restore the paint. You can really use any brand of paint cleaner, I wouldn't use rubbing compound. I persoanlly like Meguiar's, so I use Meguiar's Premium Paint Cleaner - it's great.
You will then need to "Polish" the paint. This will give the paint a wet look and create a mirror like finish.
Lastly, seal the paint with a good Carnuba wax.
You don't need a power polisher, if you are willing to put in some elbow grease. Always use a different cloth for the different steps.
Some of the larger companys sell a 3 step process which works really good.
First try a small area of your paint - I hope you will be amazed with the results.
RG.
Old Jul 12, 2002 | 07:29 PM
Chuck 6083's Avatar
Chuck 6083
Buffing out paint
Thanks for the info! I will give it a try!
Chuck
Old Jan 8, 2003 | 07:55 PM
michalangelo's Avatar
michalangelo
Buffing out paint
Hey Chuck! I've been detailing for about ten years now and old paint is very unpredictable. Sometimes it shines up with compound and other times it fades it even more. I would say try a good wax first and put a couple of coats on it. I personally use Zymol, it has worked great for me. They also have a soap that does not take wax off. If that does not work, then you may want to try compound. Watch out for swirl marks. Mike
Old Jan 9, 2003 | 09:01 AM
Carlene's Avatar
Carlene
Admom
Buffing out paint
capngu
17
Oct 3, 2016 09:45 PM
Redneckfordf2502002
2009 - 2014 F150
Mar 10, 2015 11:57 AM
Flip4ford
Kansas Chapter
Sep 6, 2007 08:52 PM
Chuck P.
1983 - 2012 Ranger & B-Series
Mar 10, 2000 11:14 AM
