Lariat Wheels
Old Feb 26, 2009 | 06:50 PM
  #31
Power Kid's Avatar
Power Kid
4k max is rear.
Old Feb 26, 2009 | 07:46 PM
  #32
Power Kid's Avatar
Power Kid
Originally Posted by Bsimmer3000
I dont recon they even know about this problem. I didnt until i looked at the door sticker. All my data shows 1500lb payload but my door sticker says otherwise. After all this there could be a problem with the info on my sticker. I cant see why they would make a truck that cant even carry 5 people without being illegal.
I don' think that is new. Think back to a 97 F150. GVW of 6,000lbs that year. Now I knw those trucks wer lighter than the 04+ but I'm sure with 5 real dudes in their they'd be over too.
Old Feb 26, 2009 | 07:49 PM
  #33
Bsimmer3000's Avatar
Bsimmer3000
Perhaps truck really aint designed for men but 12 year old boys lol. Thats the only way you wont go over payload limits lol
Old Apr 2, 2009 | 01:11 PM
  #34
lilrezs's Avatar
lilrezs
why does book say 1560lb payload on dorr 1280
Old Apr 2, 2009 | 01:17 PM
  #35
Bsimmer3000
There was a mssive thread about this but basicly what they show as the payload when you do build and price or read paper work is infact not the payload you get in your truck. No matter how you build my truck there's now way you can get the payloads they say can be had. SO you have to look into the payload before you buy. Could be 600lbs less than it shows on the web site for the spec you build.
Old Apr 8, 2009 | 07:07 PM
  #36
Toto's Avatar
Toto
I just bought a XTR, 5.4,SCREW 4x4 power bench, 18 in P rated allseasons.
Door sticker says 1417 lbs payload.That is passengers plus tounge weight and cargo.(total 1470 permitted)
If you look the extra heavy duty package includes E rated 17 inch tires, but that truck is sprung differently to accomodate E tires.
You put E tires at max preasure on a normally sprung truck and you won't like it nor will the electronic components on the truck as they get slammed arround pretty bad.
Also I don't know if the stock aluminum rims and valve stems are rated for E rated tire preasures...up to 80 psi.
Old Apr 8, 2009 | 07:40 PM
  #37
YoGeorge's Avatar
YoGeorge
P vs LT tire load ratings...
OK here we go:
All the diff factory rubber:
20" P rated Pirellis: 2403 lbs max load rating
18" P rated BF Goodrich Rugged Trail T/A: 2601 lbs max load rating
18" P rated Goodyear Wrangler SR-A: 2601 lbs max load rating
18" LT (C) rated Goodyr Wrangler AT/S: 2535 lbs max load rating
17" LT (c) Goodyear Wrangler AT/SFX4) 2,600 lbs max load rating
Just for comparson I add my current tire:
18" LT (E) Toyo Open Country A/T: 3,415 lbs max load rating
Not a big diff amoung stockers there. The big shocker though... The factory 18" LTs have a LOWER max load than the other P rated 18"s???
If I add them all up I don't get it. Rear axle max is what... 4,000lbs yet thats still less than max tire load rating, even for the lowest ranked Pirellis. So what gives? Hopefully a tall forehead can explain to me.
I know I'm very late to this thread, but when P rated tires are used on a truck application, the max load rating is to be REDUCED by 9%. This is part of the DOT requirements.
The LT tires already have the 9% load reduction built into their max load rating. So the LT's actually do have a higher load capacity than all the P's....
George
Old Apr 24, 2009 | 07:02 AM
  #38
muskoka_smurf's Avatar
muskoka_smurf
Did anyone figure this all out. I ordered a Lariat with 20" and after reading many posts am wondering if I should have ordered the 3.73 rear axle because of the bg tires. But this forces me into the Max Trailer tow $940. Minus the Trailer brake controller (which is what I ordered) this leaves an additional $700. If the 20" already come with the upgraded rear springs then are the remaining options worth it? What is the normal sterring gear ratio and is the upgraded rear bumper much different than the regular? What is the front eye bushing? Any help would be appreciated. By the way I have a brake controller on my currrent truck that I have never used in 10 years as all my trailers are single axle, but I put it in, in case I needed to pull some friends trailers.
Old Apr 24, 2009 | 09:04 AM
  #39
Ryan50hrl's Avatar
Ryan50hrl
general grabber hts has a 20 inch option for 2833 for load
Old Apr 24, 2009 | 09:12 AM
  #40
muskoka_smurf
Wow my spelling is really bad
bg tires - big tires as in 20" tires
sterring - steering
Old May 23, 2009 | 09:11 PM
  #41
NY-Ford-Lifer's Avatar
NY-Ford-Lifer
Want a set of unused Lariat wheels from 2004?
JeffD11n
Nov 26, 2013 05:48 AM
Firekite
Mar 1, 2012 11:25 PM
Billyge3
2009 - 2014 F150
May 16, 2011 12:44 PM
timcpa
2004 - 2008 F150
16
Jul 7, 2008 08:33 AM
kcduece25
Feb 12, 2007 04:19 PM
