gauges
Old Feb 24, 2009 | 07:48 AM
lowbed dud's Avatar
lowbed dud
has anyone mounted their gauges above the rearview mirror? if so any pic's
and would wireing harnes and egt be long enof,with out splicing.
thanks al
Old Feb 24, 2009 | 09:17 AM
kupaa's Avatar
kupaa
Originally Posted by jkidd_39
Do you have the dimmer switch from ITP wired in?
No,just the stock dimmer.I have a small toggle switch from radio shack that i have to put in to turn the lights off.
Old Feb 24, 2009 | 09:42 AM
USAF CCM's Avatar
USAF CCM
thanks al
I just had this done; you must spice in longer wire. I now have four gauges over the mirror (Fuel Press, Eng Oil Temp, Eng oil Press, and HPOP). Pictures will soon be added.
Old Feb 24, 2009 | 10:42 AM
Ponyboychris's Avatar
Ponyboychris
I'm not 100% certain but I've thought that you cannot add/or subtract length of the EGT wires. It messes up the calibration of the gauge. Please correct me if I'm wrong on this. All other gauges are OK though.
Old Feb 24, 2009 | 11:08 AM
CSIPSD's Avatar
CSIPSD
Most gauges have enough wire for the EGT to make it up there... Isspro Performax are the most syfisticated gauges on the market right now and offer more options then anything on the market. They have a perfect match for the stock lighting, font and bezel...
All Isspro Performax and EV2 are LED lit...
Old Feb 24, 2009 | 11:10 AM
triskit16's Avatar
triskit16
I think you CAN go longer with the pyro, but you cant solder the wires back together, you need a crimp connector...read it on one of the sponsor sites...
Old Feb 24, 2009 | 11:12 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Originally Posted by Riffraff Performance
I am happy to help you save some money and decide if you would like. Isspro Performax have a $100 cash rebate right now.
If you need pics just look a Joe's "cockpit" in his gallery
Old Feb 24, 2009 | 11:44 AM
brian42's Avatar
brian42
Veteran: Navy
x2 on that. Joe (CSIPSD) has 16 or 17 gages installed in his 250.
Old Feb 24, 2009 | 11:47 AM
Ponyboychris
Good to know. My Autometer Ultralite series EGT gauge came with a bunch of extra length of wire and it's looped in the engine compartment. I bet it can reach the mirror mount.
Old Feb 24, 2009 | 12:33 PM
CSIPSD's Avatar
CSIPSD
Shhhh Dont tell anyone, my wife has Cobalts in her Excursion in the over head pod... There is plenty of lengh for the pyro...
Old Feb 24, 2009 | 01:42 PM
jeff7825's Avatar
jeff7825
I've got the Dipricols and they are awesome.
Old Feb 24, 2009 | 01:48 PM
Izzy351's Avatar
Izzy351
Originally Posted by jdecker88
///SNIP///
Joe did you ever fill in that bottom pod?
About to. The Terminator ScanGauge is going in there soon. Haven't had the time to get to it just yet. I haven't even had time to wash the truck in the last two or three months.
Old Feb 24, 2009 | 04:42 PM
  #28
CSIPSD's Avatar
CSIPSD
https://www.ford-trucks.com/forums/a...hp?albumid=530
Here is a few pic's... I will up load more to that as I can...
Old Mar 25, 2009 | 03:18 PM
  #29
pdx02's Avatar
pdx02
Originally Posted by Izzy351
I have the DiPricols and highly recommend them. BUT, Clay is offering a deal that would be hard to pass up. Personally, I don't like those blue gauges. I like them to match the stock cluster, and the DiPricols match PERFECTLY. I think IssPro has a set that's pretty close too. The nice thing about the DiPricols are that they are lit with LEDs -- no light bulbs to worry about. Here's what mine look like:
I am curious as to how you can the wires for the dp tuner down and into the dash area. Did you take a small notch out of your pillar gauge bracket and run the wire down that way? I was thinking that there must be some way to sort of work it down in the left side without having to cut into anything.
Old Mar 25, 2009 | 03:59 PM
  #30
CSIPSD's Avatar
CSIPSD
Its very easy... Just tuck it in there. Mine is in the same location, just on the inside of the pillar.
