1st post--Glow plug installation question
Old Mar 10, 2009 | 06:36 PM
e.alleg's Avatar
e.alleg
Great info on this site. I've been thinking about swapping out the glow plugs myself. Out of curiosity how long do the glow plugs normally last? Like should they be changed like spark plugs every 50k miles or so? Do the gaskets and harnesses need to be replaced at the same time?
Old Mar 10, 2009 | 06:49 PM
rebelchevy02's Avatar
rebelchevy02
My truck turned 200,000 miles last night. Still has the oem glow plugs, and started all winter with our pennsylvania winter. The first thing to start with is the glow plug relay, for sure.
Old Mar 10, 2009 | 06:51 PM
mybigredford's Avatar
mybigredford
Originally Posted by rebelchevy02
If you have some patience, some mechanical knowledge, and a little time, the glow plugs arent a terrible thing to replace. You remove both CAC tubes, (which all 4 boots should be cleaned well) and then the valve covers, and your in. Unhook the wires, remove the plugs. Crank the engine over my hand a few revs, then install new, and reverse the process. But I would most certainly start with the stancor GPR from the link to Guzzles site.
why do you have to crank the engine over a few times?
Old Mar 10, 2009 | 06:56 PM
PaysonPSD's Avatar
PaysonPSD
At 98k I had one bad GP. I am sure some still have 8 good GPs at 200k. Best thing to do is ohm them out. I changed all 8 and have 7 good spares. I wanted to remove the VCs anyway to re-torque injector hold downs and rocker bolts as well as install UVCH retainers so changed the GPs while in there. VC gaskets are reusable and so are the harnesses if the pins are not burnt or other wise damaged.
Edit: A little slow as usual.
Old Mar 10, 2009 | 06:59 PM
rebelchevy02
When you replace the glow plugs, theres a good chance some of the residual oil will go into the cylinder. So to remedy that, I hand cranked it over some. You may not have to, but I was happy with the extra insurance. Then I reinstalled the new plugs.
Old Mar 10, 2009 | 07:00 PM
PaysonPSD's Avatar
PaysonPSD
Oil with flow into the cylinder through the glow plug hole. You need to get the oil out of the cylinder so it will not hydro lock. I vacummed the oil out of each cylinder through the GP hole.
Edit: I'm Still slow
Old Apr 11, 2009 | 07:45 PM
hgoody77's Avatar
hgoody77
were do you ohm out the glow plugs to test those? seems like my relay is working. power in power out.
Old Apr 11, 2009 | 08:13 PM
danskool's Avatar
danskool
Go Bills !
At the top of each valve cover you will find a plug.
The connector that goes under the valve cover.
The wires are as follows.
GlowPlug,glowplug.injector.injector.common.injecto r.injector.glowplug.glowplug
Old Apr 11, 2009 | 08:15 PM
hgoody77's Avatar
hgoody77
ok cool, whats the standard for the readings. how many ohms? good or bad, + or -
Old Apr 11, 2009 | 08:17 PM
F350-6's Avatar
F350-6
0.1 - 2.0 ohms is a good reading. Check the glow plug pins against a good ground to get the ohm reading. The battery ground works well for this.
Old Apr 11, 2009 | 08:55 PM
hgoody77's Avatar
hgoody77
awsome man, thanks. i like your signature too. sending reps.
the
Aug 6, 2011 08:59 PM
ttttmaxx
Dec 24, 2008 10:19 PM
curtisch
19
Oct 1, 2007 01:02 PM
z28kilr
13
Jun 7, 2007 02:19 PM
ac1108
Dec 4, 2006 11:43 AM
