Well good luck with good and cheap and original
Had to replace mine last year........ quoted over to $200 just to re-core the old one..... so I installed a 91 Explorer Core...with slight heater box mods...... now I got a good cheap heater core
I just had to replace mine in my 53. Midfifty did not have one with the same setup on the tubes. I took mine to an area radiator shop. They used a core from a newer truck and just welded my heater core's tanks to it. It cam up about a 1/4 inch shorter but everything else the same. Fit in without any problems. Only cost me $100 dollars. Cheaper then MF. Check with a radiator shop in your area.
