Sponsored by: Real Truck
does anyone know rears
Old Feb 23, 2009 | 07:41 PM
bigtuna128's Avatar
bigtuna128
my rear is making a grinding nose and not sure of two things. cost to replace and whats the common problem there.
Old Feb 23, 2009 | 07:53 PM
Ziggy.'s Avatar
Ziggy.
Is it making the noise all the time? only in turns? only when you coast? or only on accel?
The cost will depend on what the problem is. Just need a little more info
Old Feb 23, 2009 | 07:57 PM
ReAX's Avatar
ReAX
You may want to go to a doctor, grinding isn't right.
For the rear axle, Grinding is most likely a gear out place or low on fluid. You could have a bad bearing that is letting the gears out of mesh or a overtorqued crush collar or failed gears. An axle rebuild should be $1200-2000 depending on what you put back in (ie locking or LS diff, which gears, all new bearings, fancy diff cover, expensive fluid). A new axle is probably $2-3k and a used one something like $1500-2k.
Old Feb 23, 2009 | 07:59 PM
bigtuna128's Avatar
bigtuna128
its hard to tell at high speed does sound like it but at low and coast its lou and reverse nothing
Old Feb 23, 2009 | 08:20 PM
high ho silver's Avatar
high ho silver
this is starting to sound like a proctologist consult.......
