Pin striping
Old Dec 9, 2002 | 01:28 PM
RedLariat's Avatar
RedLariat
Pin striping
My truck has the tackiest pin striping on the side, can anyone tell me the easiest way of removing it? Will a hot iron, or blow dryer help?
Also, I have a slow drip from the top of my windshield right above the steering wheel. What would be the easiest way to fix this? From the outside or the inside?
- Rob
'90 F-150 XLT Lariat
32" BFG Allterrains
Few Lund Accessories
Old Dec 18, 2002 | 05:37 AM
bentkey's Avatar
bentkey
Pin striping
I too would like to know how to remove old pinstriping.
Thanks. Jimmy
Old Dec 18, 2002 | 06:30 PM
RedLariat's Avatar
RedLariat
Pin striping
I tried removing it with a blow dryer, and a whole lot of patience. It worked pretty good, just pick with an exacto blade. I'm in the process now of removing the glue with gasoline... and then I'm gonna have to do a decent amount of touch up painting. S'ok though.. looks 10 times better.
- Rob
32" BFG Allterrains
A few Lund Accessories
Old Dec 18, 2002 | 11:16 PM
10charlie2's Avatar
10charlie2
Pin striping
If/when you get the actual pinstriping off, use some stuff called "Goo Gone" to get rid of the glue residue. Works pretty good and don't have to worry about any paint damage. Be prepared to buff over where the pinstriping was, as the paint may be a littler "brighter" than the rest of the rig.
Old Dec 22, 2002 | 09:53 PM
bentkey's Avatar
bentkey
Pin striping
I have removed the old pinstriping and chrome. Now the holes that are left need filling. What is the easist way? I have never done body work before.
Old Jan 15, 2003 | 03:15 PM
John Boswell's Avatar
John Boswell
Pin striping
Astro tool company makes a pinstripe removal tool. It's like a grinder, only it's made of rubber like a pencil eraser. You can attach this to an air tool they sell, or just stick it in the chuck of your electric drill. It takes off the pinstripes and most of the glue pretty quickly. I did my whole van in under an hour. Then you just need to use either Goo-Gone or something else to remove the rest of the glue residue. The tools and the wheels are available at body repair supply shops. I think the wheels are like $10.
Old Jan 16, 2003 | 01:16 AM
benz302's Avatar
benz302
Pin striping
cold_beer839
Jan 7, 2017 09:41 PM
lucasred
Sep 17, 2016 01:47 PM
CBSuperduty
May 27, 2016 02:30 PM
FORDF100SB
Jun 1, 2015 12:18 AM
Tom Burgee
Apr 20, 2014 06:16 PM
