Aftermarket Products
Sponsored by: Worksport
Interior Light assembly for '90 Ranger XLT
Old May 16, 2000 | 06:40 AM
edene's Avatar
edene
Wanting to modify or change the interior light assembly of my '90 Ranger XLT. Problem: there's no way (short of wedging some foreign object between the door and the spring-loaded trigger) to turn off the interior light while keeping my doors in an open position. I don't want to pop the light's cover and pull the bulb either.
Question: is it possible to install a 3-position light assembly from a non-Ford derivative (ie: Mazda)? Are there aftermarket products for this purpose, and if so, is there a website or phone number to call? Looking for ideas, please.
Old Jul 19, 2000 | 03:23 PM
73Custom's Avatar
73Custom
I assume that you are trying to work on the light itself and don't want it to be powered while you do so. If that's the case then you should just disconnect the battery, and then reconnect it when you are done.
In my '73 I just took it out with it hot, it won't hurt anything, worst is you may blow a fuse if you short it out, not that big of a deal.
Any light that you like and that will fit is an option. With a little imagination, almost anything is possible.
Marty
Old Jul 23, 2000 | 09:13 PM
dust3's Avatar
dust3
1.3mazda
1983 - 2012 Ranger & B-Series
May 1, 2009 09:44 PM
BigB4000
Jul 22, 2005 09:53 AM
Crimedog54
Oct 3, 2003 08:28 PM
mikemike
Jun 12, 2002 03:50 AM
jimduke
1997 - 2003 F150
Jun 22, 2001 04:01 PM
