door ajar sensor stuck
Old Oct 2, 2003 | 11:30 PM
Crimedog54's Avatar
Crimedog54
99 ford ranger XLT...my door ajar sensor in the door stays on, therefore keeping the interior dome light on. The only cure I've found so far is 1) pull the fuse; or 2) spray contact cleaner in the lock. Anyone else run into this problem and have a more permanent solution?
Old Oct 3, 2003 | 06:09 AM
droptop's Avatar
droptop
Welcome to FTE!
Well known problem with Rangers. I think most everyone has has this problem. WD-40 or Contact cleaner works the best. Just spray a liberal amount into the door lock and slam the door a couple of times. Repeat every couple of months.
Only "permanent" solutions that I've heard of are 1) replace the switch in the door- That is a real pain to do and 2) cut the wires to the switch- I think that WXboy did that and could give you details. You can do a search within this site on the topic to get more of the posts listed on this subject
Old Oct 3, 2003 | 09:47 AM
greenpus's Avatar
greenpus
https://www.ford-trucks.com/forums/s...hreadid=105594
Old Oct 3, 2003 | 08:28 PM
WXboy's Avatar
WXboy
IF my '03 starts doing it this winter, I swear I will kick the door in. Why on Earth Ford hasn't corrected a COMMON problem they've had with the truck since 1995 I have no clue.
Brenda Lamka
Feb 21, 2014 09:58 PM
GTBksRule
Electrical Systems/Wiring
Apr 22, 2013 01:47 PM
62star
Jul 29, 2012 03:58 PM
TampaDave
May 5, 2010 05:04 AM
calibob
1997 - 2003 F150
Dec 27, 2008 01:47 PM
