Wheres the starter solinoid located?
Old Feb 22, 2009 | 09:56 AM
Yougotthehit's Avatar
Yougotthehit
Ok its not on the wall like the 7.3, so wheres this baby at!
Old Feb 22, 2009 | 10:03 AM
toolman05kr's Avatar
toolman05kr
They use a relay located in the drivers side electrical distribution box. Check your owners manual for it's location in the box.
Old Feb 22, 2009 | 10:40 AM
Yougotthehit
There has to be a solenoid, cant just be a relay every vehicle has a solinoid that some way or another powers the stater.
Old Feb 22, 2009 | 10:42 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Build into the starter....
Old Feb 22, 2009 | 11:01 AM
toolman05kr
What you were asking about was the 4 terminal switch that that used to be on the passenger side fender, Part # sw1 or sw3. on all powerstroke engines the actual starter solonoid is mounted on the starter and this device throws the drive into the ring gear as it completes the connection to battery power allowing the starter to recieve electricity thus allowing it to rotate and turn over the engine. ford finally figured out that this solonoid can be controlled by a small relay, and to save money and weight, went that rout on the 6.0's ( The other manufactures have been doing this for a long time on their diesel pick-ups and vans). Soooo, If your looking for the thing that used to be on the fender, do what I told you to.
hanklin
21
Jul 26, 2016 09:54 AM
dj lpm
2015 + Expedition & Navigator
Apr 15, 2016 12:31 AM
FilmCarp
Testing.....
Nov 16, 2014 07:50 PM
Sawsall
Feb 11, 2008 11:01 AM
ryanstruck
Ford vs The Competition
18
Feb 3, 2001 06:44 PM
