Need some help/advise rough start
Old Feb 22, 2009 | 11:02 AM
lsramek1's Avatar
lsramek1
Hey all you guru's I need some help/advise. A few days ago my 05 started acting wierd on startup. It only happens if the truck sits over night or for 8 hrs or so while I am at work. When I start the truck it acts like it is not getting fuel. It will start and kind of stumble/miss for a minute and then runs fine. Honestly it acts just like it did the one time I accidentally ran it out of fuel. Any one have any ideas? I have already changed both of the fuel filters, no help. I am not seeing any codes on my SCT X3. I run PS Grey bottle each fill up. I live in Dallas so no issues with fuel gelling or anything. I should mention that a while back someone tried to steal the truck, so I put in a kill switch to the fuel pump. Wouldn't think that would cause the issue as when I deactivate the switch I hear the pump come on and I don't try to start until after it goes off. Going to call a couple of dealers and see what they say.
Old Feb 22, 2009 | 11:06 AM
toolman05kr's Avatar
toolman05kr
Have some one check your fuel pressure. some 05's are prone to fuel pump cases rusting and messing up the fuel pressure regulator pintal seals. fuel pressure should be around 55psi
diesel-fitter-bum01
Mar 20, 2012 08:12 PM
snapper4691
1997 - 2003 F150
Oct 9, 2011 09:10 AM
wolfeman
1978 - 1996 Big Bronco
26
Mar 9, 2004 04:57 PM
kwanderi
Feb 8, 2004 05:17 AM
