80- 86 pickup Engines
Old Feb 22, 2009 | 07:20 AM
Retiredfire's Avatar
Retiredfire
Red face 80- 86 pickup Engines
Would a 302 V8 or a 300 six be a good swap into a 1990 150 ? I bought a 1990 F-150 pickup with No engine or tran. I have some 1983 ford pickups
Old Feb 22, 2009 | 08:09 AM
Camo93XLT's Avatar
Camo93XLT
The early head design isn't up to par with the later E7 heads but you can find E7s all day long for $50 a pair. Are you wanting to stay carb or go fuel injection?
Old Feb 22, 2009 | 08:44 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
What was originally in the '90?
It would be much easier to go with what engine perches, exhaust, computer and engine harness it is already setup for....
Old Feb 22, 2009 | 09:14 AM
Retiredfire
Red face 80-86 engines
The 1990 had a 302 V8 .Some one got the engine & tran. out of it The body bed paint are great shape.
Old Feb 22, 2009 | 09:29 AM
Camo93XLT's Avatar
Camo93XLT
Well if the fuel injection stuff is gone along with the harness it sounds like a good canidate for a 302 carb swap.
Old Feb 22, 2009 | 10:18 AM
rikard's Avatar
rikard
Just be aware that the feds don't want you putting an older engine into a newer truck because of emissions. If your state does emission testing it could be an issue or if you sell it to someone without disclosure about the engine change. That being said a carb engine would be the easiest swap. The EFI uses electric fuel pump(s) so you'll have to modify that for the carb.
regards
rikard
Old Feb 22, 2009 | 11:05 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
No need to modify the in tank pumps.
You'd just need an aftermarket FPR and some wiring to get the pumps operating correctly without the computer I'd think.
Old Feb 22, 2009 | 12:10 PM
Conanski's Avatar
Conanski
An EFI 302/tranny combo would be a relatively easy bolt-in though, no need to wire up gauges, ignition, fuel.. it's already there.
