Van Turbo Rebuild Problems... HELP Izzy, BDrummonds, ANYBODY!!!
If the the stock housing is clearing, then there's an issue with that ported housing. My ATS has no problems -- I'd call Dennis today and see if there have been any other problems with that housing. Ron sells that same housing, so you might call him to see if he's ever had that problem as well.
Thanks for all the advise and I'll let you know how it goes!!
Well, used some 220 grit sandpaper and smoothed up the radius where the wheel was touching. There was a small ridge all the way around from the factory machining. Although the wheel wasn't hitting it all the way around, I smoothed it up too. Then followed with some 400 grit for a super smooth finish. Happy to report all is good and there is no more contact between wheel and housing!! Will be installing this weekend.
Is there any way to measure the clearance between the housing and the wheel? I'd sure hate to see things move a little when that turbo warms up and tear itself to pieces. (I hate to be devil's advocate, but someone has to do it! Yes I am an agent of Satan, but my duties are largely ceremonial )
I'm sure there is but I darn sure don't have the tools to do it. As far as expansion/movement of parts when it's warmed up, someone else would have to chime in on that thought. From what I've seen on stock turbos, there's very little tolerance between the wheel and housing. Probably designed that way for the best air flow and efficiency. But again, someone could better explain it.
workingdog
31
10-10-2016 02:21 PM
horsez2go
11-11-2013 10:23 AM
